<~----> Is it possible to get a virus across a network? - Hardware Canucks
Old May 2, 2011, 08:53 AM
Default Is it possible to get a virus across a network?
Im having fun with VM ware on my laptop trying to purposely get a virus to see what my AV can really do, but I am worried that I may infect my main PC which is on the same network. Filesharing is not enabled, but both pc's connect to the same router. Is it possible to get a virus on my main PC if this one has a virus too? I have a very strict firewall on my main PC (Eset Smart Security) on learning mode so only I can choose what gets in...\ please help ty.
Of course it is. But it depends on the virus and if it can infect machines across a network.
Old May 2, 2011, 09:19 AM
Shadowmeph's Avatar
Usually Virus's spread from file sharing So if you are Sharing a file that has a virus it will get the Virus, can be very tricky they can be in the form of a jpeg in which you open the picture ( jpeg) and then spread onto your machine without you even knowing it and either activate right away or just sit there waiting. there are some virus's out there that are written to shut down and break you AV and punch a whole through your firewall.
suppose file sharing is off, which it is how would it transfer the virus over? also i ran scans on the VMware machine within the laptop, it found all 24 viruses :) Just testing my AV, so I guess I shouldn't worry as I have the same AV on here + more protection LOL. what are the chances and how the hell does the said virus get to my computer from another computer on the LAN?
Old May 2, 2011, 09:34 AM
hmm, i did execute every file on the virtual machine and nothing big happened... im still scanning my PC though. mind you I had AV on the virtual machine, it was just disabled.. ALSO my firewall on this computer (ESET Smart Security) is password protected and on learning mode so I can see what accesses the internet. adn again filesharing is off.
Old May 2, 2011, 09:48 AM
Shadowmeph's Avatar
People that I know that play around with Virus's do so on an older machine with the Internet unplugged
Old May 2, 2011, 09:56 AM
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old May 2, 2011, 10:56 AM
Perineum's Avatar
Conficker is an example of a very well written network aware virus. The guy who wrote it actually gets my respect for how virulent it is. It will break into network shares that come default on Windows installs, etc
However, in your case I think you're probably perfectly fine on your main computer. It sounds like you're taking enough steps and being careful enough.
Old May 2, 2011, 11:37 AM
Lpfan4ever's Avatar
Very possible. And I agree, conficker is a bastard.
Originally Posted by encorp
Code:
<firebane> slightly used
Old May 2, 2011, 12:11 PM
Blaster worm is probably one of the worst network ones that had spread horribly!
Everyone remember.. "Your computer will now shut down in 60 seconds" the second you plugged into the internet!
Do I have a virus? NineLives Troubleshooting 7 August 25, 2010 12:00 PM
help remove virus hohohee Off Topic 16 July 12, 2010 03:29 PM
Virus Woes Kayen Troubleshooting 22 May 22, 2010 08:06 PM
Problems with a virus TimTheEnchanter O/S's, Drivers & General Software 8 May 11, 2009 12:54 PM
Virus problem...Help Kilauea O/S's, Drivers & General Software 21 August 22, 2008 08:21 AM
