Old April 23, 2011, 06:24 AM
Arrow ubuntu - please advice
Hi,
this is for my cousin .he is downloading ubuntu 32bit desktop version now.
he has xp and win7 32bit in his pc ..
have some doubts
1.he has xp in c driver win 7 in d drive .planning to install ubuntu in e drive ..is this setup ok ?
2.how safe is ubuntu ? he is planning to use this one for browsing
3.is there any internet security available for ubuntu ?
4.is it possible to install yahoo messenger in ubuntu ..for video chat ?
5. is it possible to play crysis or any other games in ubuntu? (he has a gts 250)
please advice friends
Old April 23, 2011, 06:28 AM
1) Yes
2) Safer than Windows
3) Not needed
4) There are alternatives that may work
5) No
Old April 23, 2011, 09:22 AM
Neolithium_Wpg's Avatar
There's a bunch of instant messenger clients for linux, it'll be easy to find one. As for games there are some fun ones for Linux as well, he also MAY be able to use Wine to play a few, however performance varies with machines and nothing is guaranteed to work. Linux isn't a gaming platform.
WineHQ - Run Windows applications on Linux, BSD, Solaris and Mac OS X
Dell XPS8700 | Asus x101ch | iPhone 5 (iOS7)
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
Old April 23, 2011, 09:35 AM
Wine only works so well for certain things.
The biggest issue is getting a web cam to work. Support has gotten WAY better but it can still be a hit or miss.
Old April 23, 2011, 10:37 AM
JD JD is offline
Although not the most ideal solution, you could always run VMware/VirtualBox/etc to run Windows for Yahoo Messenger within Ubuntu.
But I'm sure you can find some native Linux client that will work.
Old April 23, 2011, 11:40 AM
Shadowmeph's Avatar
Ubuntu is a Good Linux distro for the average user that is used to Windows . there is a surprising amount of free software out there which runs off of Linux that is just as good and sometimes better then Windows based software it is just that most people are Brain washed to use Microsoft things
Old April 23, 2011, 12:27 PM
why webcam is a issue in ubuntu ?
there is a new version of ubuntu (11.04) releasing this april 28th. will it solve such issues ?
Old April 23, 2011, 12:28 PM
Because a lot of webcams require specific drivers and linux may not cater to them.
Do your research first.
Old April 23, 2011, 04:58 PM
ZZLEE's Avatar
Make sure to update Ubutu
I was hacking pass words or folding fore some one on mine shortly after I installed it on my computer.
Up dates fixed it.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old April 23, 2011, 05:10 PM
sswilson's Avatar
Can he get his hands on a second (smaller) HDD? If he wants to run a dual boot system, but wants to ensure that his win7 install doesn't get messed up, I'd suggest disconnecting his win7 drive and installing ubuntu on a completely separate drive. That way he can use whatever F-Key his motherboard uses to select between the two drives as boot drives.
Ubuntu Help Rommel O/S's, Drivers & General Software 11 May 13, 2010 06:59 AM
Ubuntu apps miggs78 O/S's, Drivers & General Software 11 August 24, 2008 03:18 AM
Ubuntu 8.04 miggs78 O/S's, Drivers & General Software 3 August 7, 2008 04:06 PM
Ubuntu 8.04 install Osnaz O/S's, Drivers & General Software 2 July 30, 2008 08:01 AM
Dell goes with Ubuntu Babrbarossa O/S's, Drivers & General Software 14 May 3, 2007 01:12 PM
