Old April 19, 2011, 01:28 PM
botat29's Avatar
Default Booting from an USB don't work
Hi, I create a USB install disk of sbs 2011 , the reason is that I don't have double layer dvd for the 6gb iso
on 2 different Asus board with Intel chipset no problemo, it boot from the USB
on this &%$(** MSI AMD 890fx chipset NO WAY I get read error press alt-del ...bla bla bla to restart and of course it's on this one I want to install it .
I set up to boot from USB I press F11 when booting no way, the funny part it work with a win98 usb boot disk
any Idea ?
Old April 19, 2011, 01:35 PM
Shadowmeph's Avatar
it is setup as a USB boot? it can be a little tricky setting up an ISO then changing it to a USB and having it boot from the USB .
Just to make sure here is a link on how to do it How To Install SBS 2011 With A Bootable USB Drive | NoGeekLeftBehind.com
Old April 19, 2011, 01:39 PM
ZZLEE's Avatar
Try " Escape " from a Cold Boot. Press it keep it Pressed. Select Boot Device Myght Come Up hopefully.
Select Hard Drives/ USB Stick/
Try That
EDIT: 3oh6 fore boot from USB BIOS Flashing Guide :: USB Stick BIOS Flash for X58 SLI...
might be helpfull
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old April 19, 2011, 01:44 PM
botat29's Avatar
If you read my post I said it work on 2 others PC so the stick is bootable.
Old April 19, 2011, 01:47 PM
botat29's Avatar
Try That
that's what I did with the F11 it bring the boot menu but the problem is in reading the disk
Old April 19, 2011, 01:50 PM
Shadowmeph's Avatar
I wasn't sure that you where using the same one stick. also is it formatted correctly I think that win98 boot is allot different then this one because this is NTFS
Old April 19, 2011, 01:51 PM
ZZLEE's Avatar
Un plug it ? un plug stata conector. have usb as only disk. ?
Old April 19, 2011, 01:53 PM
botat29's Avatar
gone give it a try for troubleshooting ...but I will need a HD to install the OS
Old April 19, 2011, 01:56 PM
botat29's Avatar
may be I should create the disk on the AMD insted ?
Old April 19, 2011, 02:04 PM
ZZLEE's Avatar
What is the system spec of what we are trying to get this on ?
Webcam and Win 7 don't work ? ? bonanza2000 Troubleshooting 15 March 16, 2011 05:01 PM
Booting from USB xilocient Troubleshooting 5 June 13, 2010 03:16 AM
HwC, Yahoo and other don't work MarkOne Off Topic 3 March 7, 2010 08:57 AM
PCI Slots don't work? JD Troubleshooting 7 December 12, 2009 10:24 PM
Problem booting freenas from USB klaiboi O/S's, Drivers & General Software 4 December 4, 2009 10:48 PM
