Old April 19, 2011, 02:17 PM
botat29's Avatar
Originally Posted by ZZLEE View Post
Un plug it ? un plug stata conector. have usb as only disk. ?
so the AMD have 1 ssd and 2 sata drive, since I will not use the ssd , I remove it , and guest what it's working, but it's an issue with AMD board or MSI because both Asus I try it have also an SSD in them ....
Old April 19, 2011, 03:17 PM
ZZLEE's Avatar
Plug back in just the drive you want it on .
GOOD TO GO
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old April 19, 2011, 03:30 PM
botat29's Avatar
GOOD TO GO
Actually I just remove the SSD, the 2 others drives are there and it work it's installing now.... very easy to do just few questions, tomorow I will configure Exchange and add another server 2008 r2 as second controler
thansk a lot ...... where do you get the idea to remove a drive ?
Old April 19, 2011, 03:51 PM
ZZLEE's Avatar
"Coch Coch" LINUS
only one drive fore boot to insall windows because of Kerrnel
only sorce and destonation drives fore isnitall set set up on Windows 7
The Kerrnel will get Stashed anywere if you don't
Webcam and Win 7 don't work ? ? bonanza2000 Troubleshooting 15 March 16, 2011 05:01 PM
Booting from USB xilocient Troubleshooting 5 June 13, 2010 03:16 AM
HwC, Yahoo and other don't work MarkOne Off Topic 3 March 7, 2010 08:57 AM
PCI Slots don't work? JD Troubleshooting 7 December 12, 2009 10:24 PM
Problem booting freenas from USB klaiboi O/S's, Drivers & General Software 4 December 4, 2009 10:48 PM
