I am not clear on what you are asking, if a file is automatically opening something when you actually want to use something different to open the file I usually just rightclick and go to properties click on the general tab and on most files ,inside the general tab there is a "opens with" and change I select change and then use what ever.
now if that is not what you are saying and you are saying that just clicking on a file it automatically opens then maybe the mouse settings are not set to double click to open file, they may be set to single click to open file.
