Old March 21, 2011, 06:04 PM
bvsbutthd101's Avatar
Default (Solved) Can't Seem to fix this problem????
I had microsoft security essentials installed, but it won't let me boot it up anymore.
I go to open it and it just shuts off. People said it was malware on my computer. I downloaded malwarebytes and it got rid of 7 infections. Still can't figure this out. Any advice would be much appreciated.
This happened like 30 mins after I installed Nero.
When I go to turn it on I get this message
I went on bunch of other forums to see if there was a solution for the problem.
They said go here and turn security center to automatic and press start
This is what happens when I do that
Old March 21, 2011, 06:07 PM
ZZLEE's Avatar
Are you in The Adnmin acount ?
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 21, 2011, 06:08 PM
yes, I'm the admin. I only have one account on my computer. I edit my post check the top.
Old March 21, 2011, 06:29 PM
coleo's Avatar
i removed this junk program almost as soon as i put it in.
many hassles with it. if you use utorrent at all you will be deleting this program as fast as possible
Old March 21, 2011, 06:33 PM
Shadowmeph's Avatar
I would download highjack this and run it have it set to safe file once that file is saved go to the highjackthis site and upload the file and then check the online analysis to see whats upwhat is actually running on your PC it will help you allot . HijackThis Logfileauswertung
Old March 21, 2011, 06:46 PM
I did it, everything was very safe or safe
Old March 21, 2011, 06:51 PM
Spikemaul's Avatar
Here's some links that might help: Can not turn on Windows Security Center Service - Windows 7 Forums
and another: Can't turn on Windows Security Center Service - Windows 7 Forums
These are from Sevenforums.com
Hope these help.
Old March 21, 2011, 07:40 PM
Hope these help.
i tried everything in these forms. Still no go. I even tried to do repair install but when I go to do it it says my windows has to recent of a version. So i tried unstalling service pack 1, won't let me to do that either.
Any other suggestions?
Old March 21, 2011, 09:36 PM
What malware were removed by Malwarebytes and what's the source of Nero?
With a system that has was infected, the most likely cause is that not all malicious codes have been removed or not all the damage has been repaired. Malwarebytes is a pretty good cleaner but it's not and never will be 100%, some malware are impossible to remove when the OS is running.
Have you tried running system restore from a safe boot. Boot into Safe mode with command prompt and enter "rstrui.exe" to start system restore. It should resolve problems caused by a bad software installation or hosed registry.
Start your computer in safe mode
If you cannot restore the system to an earlier point or the restore doesn't resolve the problem, then you may want to go to the following forums that specializes in malware removal and see if if your system is still infected.
Am I infected? What do I do? - BleepingComputer.com
Cyber Tech Help Support Forums
Virus, Spyware, Malware Removal - Geeks to Go Forums
5 Star Support Forums - Free Computer Help
If you want to try cleaning up the system yourself I can give you a list of cleaners, but unless you're experience with malware removal I strongly recommend that you visit one of the malware removal forums above.
iK ©
Old March 22, 2011, 08:21 AM
Tried a system restore. It only let me restore back to when I installed nero. So was still on my computer. I tried restoring it even further. I'm an idiot, I had my computer backed up and i deleted the backup off my hard drive and stop the automatic backup so I can't go any further.
I'll try those websites and if they don't help. I might just put a fresh copy of windows on.
are you clever to fix anything? CTA Off Topic 2 June 26, 2010 12:20 PM
trying to fix a 5 month old problem =/ BrianHanna Gaming 11 February 28, 2010 07:48 PM
This is how you fix your Xbox 360 Infiniti Off Topic 7 February 22, 2009 02:26 PM
Dead PSU.. Fix? Infiniti Power Supplies 13 July 23, 2008 08:54 PM
Help Fix NTLDR Gerrich Storage 13 May 6, 2008 06:48 PM
