Old January 15, 2008, 05:46 PM
Default Dual boot question
If I was to put Vista on my new PC before I put on XP, or vice versa, would there be any problems?
I heard someone saying you lose stuff from Vista if you do XP first.. and it would take alot of work to get it back..
Old January 15, 2008, 06:06 PM
Always put XP then Vista and put them onto two different partitions.
Vista will cope better with XP being installed first with its boot menu.
Old January 15, 2008, 06:27 PM
Awesome thanks man!
Old January 18, 2008, 06:55 PM
bushwhacker's Avatar
Default additional info of interest on this subject
How to make XP / Vista dual-boot Independently - MSFN Forums
How to Install XP after Vista and Fix the Bootloader - MSFN Forums
Old January 18, 2008, 08:16 PM
I can't even get XP or Linux to install and Vista didn't come today, so now I have to wait all weekend before I can do anything on my computer cause my old version of Windows IS OEM. So I pretty much won't know if there's anything wrong my system until monday, which then, if something is, it's only another week or 2 I have to wait to get a new god damn part for it. It's pissing me off because I only have a month until I'm going on tour and I wanna have this build up for the wife. I also at least wanna get some time played on it.. I'm redownloading the OS to see if maybe there was a corrupted file or something..
Old January 18, 2008, 09:02 PM
Varroa's Avatar
I just installed Vista on a second HDD with XP installed first. You choose custom install and then choose to install on a different partition/disk. It worked flawlessly and I can now dual boot. The only downfall is you get a boot loader screen during re-starts and you have to choose xp or it defaults to Vista. I know this can be changed but I haven't had time to figure it out yet.
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old January 18, 2008, 11:51 PM
I can't get anything to boot. We'll see, I now have to wait until Monday until Vista arrives... to see if Vista will even install itself. If it doesn't install then, I obviously have some faulty hardware, which I don't know what I'll do to figure it out since I run a mac....
Old January 19, 2008, 02:09 AM
Prof. Dr. Silver's Avatar
DUDE! You still didn't fix that machine? Man....take your rig and shove.....oh no...bring it towards another computer to check out all the components! Just swap them all out to see if they work properly. Does your board give you any failures on the POST display?
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old January 19, 2008, 11:06 AM
Yeah it's always reading off numbers... nothing that I was paying attention too though cause I don't know what they mean. haha I can get into the bios and everythings fine from there... it appears. I'm going to retry installing Linux, since it's a free OS.. If I can't get it, I'll be waiting for Vista, and if that don't work, I can try to plug things into my old PC, but it's 7 years old.. so half the stuff probably won't work with it anyways. My old Mobo is an AGP x8.. I don't even know if it has Sata 2 ports... they company that put it together didn't do ANY cable management.. So it'll be a mad house trying to fit stuff into it.
Old January 19, 2008, 11:10 AM
Supergrover's Avatar
msconfig
R.I.P.
How to de-couple dual boot Malam O/S's, Drivers & General Software 7 February 3, 2008 09:53 AM
won't boot up Jhayman Troubleshooting 0 December 6, 2007 10:41 AM
Dual boot vista 64 on second HD Babrbarossa O/S's, Drivers & General Software 8 December 4, 2007 01:42 PM
dual boot how to ? Jim Storage 18 August 11, 2007 05:45 PM
Vista Boot Agent question slugbug O/S's, Drivers & General Software 0 April 30, 2007 12:50 PM
