Old February 21, 2011, 10:15 AM
JD JD is offline
Assuming SP3 was properly installed, you shouldn't have to re-install the SP after running sfc /scannow.
Old February 21, 2011, 12:28 PM
Thanks for the tip. Is there a registry cleaner or tool out there that is trusted to remove registry errors and general junk. I'm skeptical of registry tools in general but programs are starting to load a little slow and I would be willing to try a recommended one before doing a new clean install.
Thanks
Jim
ASUS P7P55D-E Pro - Intel i7 860 - Zalman CNPS 10X Quiet - 4gb G.Skill Ripjaws DDR3 1333 CL7-7-7-21 1.5V - Intel 520 Series 240 GB SSD - WD Caviar Black 1Tb - Corsair TX750W - Sapphire Radeon HD 5770 1 Gb GDDR5 - DVD Drives X2 LG GH24LS50 - Coolermaster CM690 II Advanced - Win 7 Pro 64
Old February 21, 2011, 12:33 PM
Shadowmeph's Avatar
ccleaner is free and good reg cleaner
Old February 23, 2011, 03:33 PM
Tried CCleaner. Seems to work fine. But still no difference in performance. Programs still load a little slower that they used to.
Jim
Old February 24, 2011, 06:55 AM
JD JD is offline
In my experience, XP just naturally gets slower over time. I don't know why but that's just what I've experienced. Windows 7 seems to maintain a more consistent performance level.
I usually formatted XP at least twice a year, if not more. It was the only way to keep it running speedy I found.
Old February 24, 2011, 10:43 AM
You may want to try a clean boot and see if that makes a difference before nuke/reinstall
How to configure Windows XP to start in a "clean boot" state
Strange problem Charmster Troubleshooting 7 July 3, 2010 06:13 AM
Reboot and select proper boot device or insert boot media in selected boot device BrianHanna Troubleshooting 44 February 11, 2010 02:13 PM
strange google CTA O/S's, Drivers & General Software 3 March 1, 2009 01:41 AM
My Boot settings (Bootsect.bak/Boot directory) installed to another HDD? chouchou Troubleshooting 7 December 21, 2008 08:46 PM
