Old February 14, 2011, 09:20 PM
KaptCrunch's Avatar
Default w7 ultimate folder options location
heres the road map finding folser options in win7
Old February 15, 2011, 10:37 AM
JD JD is offline
You can also go to Control Panel\Folder Options just like the past versions of Windows ;)
Old February 15, 2011, 11:23 AM
or type folder in the start>search thingie and itll show you a link, good for the lazy couch potatoes :p
Old February 15, 2011, 11:49 AM
MacJunky's Avatar
Hit ALT then Tools->Folder Options.
local pickup from markham location lanken123 Off Topic 3 August 2, 2010 10:33 AM
Low Consumption Folder OR Part time POWER Folder ilya New Builds 3 May 16, 2010 03:33 PM
Radiator / Pump location Fudd Rucker Water Cooling 20 December 6, 2009 04:40 PM
Folder down redwagon HardwareCanucks F@H Team 2 October 2, 2009 12:35 PM
64 Bit Vista Ultimate and Office Ultimate 32 Bit tyreman O/S's, Drivers & General Software 5 March 22, 2009 04:54 AM
