Old February 7, 2011, 02:04 PM
RBA RBA is offline
Default Replacing Motherboard/Format?
Hello
My Asus M4A89GTD PRO/USB3 bit the dust and I had to replace it.
I purchased the Asus Crosshair IV Formula board, swapped the boards and setup the bios settings for my hardware. The system booted up fine. I uninstalled the M4A chipset drivers from the old board and replaced them with the Crosshair drivers and all seems fine. Do I need to re-format when doing a swap like this? Running Win 7 x64.
I noticed that my board is using a 1203 BIOS that is not posted on the support site. Only 1102 and 1304. Can anyone explain this? Is this just a factory revision BIOS?
Old February 7, 2011, 02:39 PM
Shadowmeph's Avatar
Well , I think that it is good practice to reformat\install everything but myself I am lazy so I don't unless there seems to be problems then I backup everything and format
Old February 7, 2011, 02:46 PM
For "peace of mind" I normally do a fresh install when swapping mobo's unless the chipsets of both boards are the same... This way if problems do crop up I know it wasn't the swap that is causing them... With that said, if everything seems to be running fine why bother...
Old February 7, 2011, 02:47 PM
maverick_brent's Avatar
Shouldn't be necessary...if troubles arise then might be something to think about
Old February 7, 2011, 03:47 PM
coleo's Avatar
Daddy always used to say if it aint broke Dont fix it
Old February 7, 2011, 05:21 PM
CTA's Avatar
CTA CTA is offline
well just remove all old drivers then update driver like i did crappy p5q deluxe to ep45-ud3... since they are almost same (p45).... if different chipest then i suggest clean install...
Old February 7, 2011, 11:37 PM
Perineum's Avatar
nah, I certainly wouldn't.
.... maybe with Win98 I would have. WinXP would just crash, which is fixable with a repair install. Done it hundreds of times with 100% success rate.
It's even easier with Windows Vista and yet again with Windows 7.
Windows 7 almost acts hardware agnostic at times. It seems to know the device is different, removes the drivers that don't work and uses ones that do...
Old February 10, 2011, 01:39 PM
RBA RBA is offline
Thanks for the replies guys. System is stable.
Replacing north/south bridge cooler Blu Peripherals 3 January 2, 2011 01:48 PM
Replacing NH-D14 stock fans? tragd Air Cooling 3 July 13, 2010 02:20 PM
Replacing 6yo Rig Adciv New Builds 8 February 18, 2010 09:33 PM
Thinking of Replacing my Aerocools Soultribunal Air Cooling 3 February 26, 2009 06:02 AM
replacing ocz gamexstream 700w fan Phobia Power Supplies 6 February 22, 2009 04:20 PM
