Old February 4, 2011, 10:06 AM
Default Solved
Well, I'm sure the title caught your attention. Yes, I am trying to get windows 95 to function with a GTX 480. I have it in a VM and don't exactly know how to get it to work right. the earliest drivers Nvidia has is for win XP..
I am using Oracle VM and have the OS already installed. I need this to work so that I may have the 256 colors needed for mechwarrior 2 and other old 95 games.
Thanks in advance.
Death to Apple
Old February 4, 2011, 10:21 AM
MacJunky's Avatar
Your GFX card is not used natively by the guest OS. The virtualization app fakes a video card so you need drivers that tell the guest OS how to handle the virtualized card.
Drivers for your physical card itself are not used.
Old February 4, 2011, 10:44 AM
Just run the game in Windows XP with Dos Box if you need to.
Neither Windows 95 or 98 do well in a Virtualized environment.
Old February 4, 2011, 12:23 PM
chrisk's Avatar
Folding Captain
Enaberif uses Windows 3.11 *for Workgroups* still as he thinks it is still good enough for what most folks want to do. ;p
Fold for team #54196
Old February 4, 2011, 12:26 PM
Ok, So what do i need to do to get the drivers needed? Cause at this point. I'm clueless.
As for windows XP, It does not function well "even in compatibility mode" with the games I want to play.
Death to Apple
Old February 4, 2011, 12:27 PM
Negative. I've tried the virtualization of Windows 95 and 98 and neither run that well or that smooth. Windows XP works well in a virtualized environment and should be able to play that game just fine.
Old February 4, 2011, 12:28 PM
Whatever program you are using for the virtualization should have a guest addons or a form of drivers for that program.
Old February 4, 2011, 02:09 PM
JD JD is offline
Find an old PC on the side of the road and use that?
Even if you can get 95/98 installed on a VM, I don't think it's going to have 3D Acceleration to play games decently.
Old February 4, 2011, 02:13 PM
VirtualBox has "3d Accel" but its very limited.
Old February 4, 2011, 02:47 PM
JD JD is offline
Yeah so does VMWare, but I'm guessing the Windows 95 drivers wouldn't have support
gtx 480 with gtx 260 for physx (power consumption question?) bvsbutthd101 Video Cards 15 July 7, 2010 10:37 PM
Koolance Releases GTX 470 & GTX 480 Full Coverage Waterblocks FiXT Press Releases & Tech News 7 April 9, 2010 07:34 PM
PNY Technologies Unveils GeForce GTX 470 & GTX 480 FiXT Press Releases & Tech News 3 March 29, 2010 03:15 PM
NVIDIA Clarifies Official GTX 480 and GTX 470 Launch Date matsta31 Press Releases & Tech News 76 March 9, 2010 02:07 AM
NVIDIA's Next-Gen Parts Get Named: GTX 480 & GTX 470 SKYMTL Press Releases & Tech News 67 March 6, 2010 09:23 PM
