Old February 3, 2011, 02:07 AM
Default CPU-Z quirk
When I run my CPU-Z under the core's heading it doesn't show the full speed of the processor just 1 core.
Should it show all core combined or what.
Old February 3, 2011, 06:58 AM
gingerbee's Avatar
just shows the speed of your chip overall not each core
Old February 3, 2011, 11:21 AM
Well then My CPU-Z must not be working right because my Processor is a E6700 Dual Core at 3.2GHz at CPU-Z is is only registering 1.6GHz.
Old February 3, 2011, 11:57 AM
MacJunky's Avatar
You probably have the clock-reducing power-savey thing enabled or something.
Post a screenshot.
Old February 4, 2011, 12:27 AM
Here's the screenie.
Old February 4, 2011, 12:39 AM
The E6700 is a 2.6ghz chip, a quick search on the Intel site confirms my suspicions.
Intel® Core
Attachment 12917
You have power savings features enabled, your multiplier should jump up to 10x when you put a significant load on your CPU, resulting in 10x266mhz=2.66ghz, the correct clock speed for your CPU.
Old February 4, 2011, 06:57 AM
gingerbee's Avatar
EIST is running thats all
Old February 4, 2011, 07:40 AM
Varroa's Avatar
leave CPUz running and then try unzipping something and see what it reads.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old February 4, 2011, 02:34 PM
You can right-click in the middle of the CPU-Z window while in the "CPU" tab to change the view to monitor another core, but you won't see anything different unless you manually set affinities for tasks.
Old February 4, 2011, 02:40 PM
gingerbee's Avatar
wow i didn't know that, see that's why i love computers always always something new to learn thanks man/woman
[FS] Motherboard (X58 and P45), lga775 cpu, am2+ cpu, gtx 260 ~NY~ Buy/Sell & Trade 6 October 31, 2010 01:48 PM
[Review] 2010 CPU Blocks RoundUp - Supreme HF, Apogee XT, Koolance CPU-360 and HK 3.0 Dazmode Water Cooling 3 May 29, 2010 06:52 PM
Can I add a cpu with slightly diff speed rating to existing single CPU config? HoTiCE_ CPU's and Motherboards 3 April 1, 2010 08:52 PM
which temps are correct? cpu, cpu core1? Shadowmeph Overclocking, Tweaking and Benchmarking 4 July 13, 2009 06:23 PM
CPU use @ 57% and inactive processe use 93% of the CPu WTH ebdoradz Off Topic 6 February 26, 2008 07:34 PM
