Old January 26, 2011, 01:12 PM
botat29's Avatar
Default Tweaking Xp on an old PC
Hi, a friend of mine ask me to install a windows XP on an old computer for his Dad, they do not have money to spent on it, the pc is an Athlon something with 256 mb of ram, so itís gone be real slow, especially if I install sp3. So here the question, do you have tricks to make this dinosaur useable for internet browsing and play solitaire. Just as info I want to sell him a PIV 4 ghz I have with 1 gb for $ 60 and itís too much for themÖ. So install more memory will be a no go too.
Old January 26, 2011, 01:33 PM
Spend the $60 and drop a gb of memory into it and that machine will run a lot better than 256
Old January 26, 2011, 01:41 PM
botat29's Avatar
thanks enaberif ...but that's the point ; they don't have $ 60 to spend on it.
Old January 26, 2011, 01:46 PM
gingerbee's Avatar
just run tiny xp if you can find it or even better run ubuntu 9/10 both work great for basics. my2cents
VVV he's right about that.
Well unfortunately without spending money on that machine you are gonna be really hurting with that machine. Being that its XP and only 256mb of memory that machine will be swapping out to the hard drive so bad that it'll really kill and slow down the machine.
Old January 26, 2011, 02:01 PM
you could lower the resolution and color scheme, 16 colors for the win
make sure no programs run in the backround like antivirus, keep it as basic as possible
Old January 26, 2011, 02:13 PM
right click on my computer,properties, advanced, settings, best performance.
,ok,ok
then disable that pathetic excuse of prefetch
then open up services.msc and go barbarian on what they wont need, like wireless and so on.
ccleaner its arse, remove all startup items, the works
Old January 26, 2011, 02:41 PM
botat29's Avatar
Originally Posted by _dangtx_ View Post
........ like wireless and so on.
holy..... they have a wireless adaptor... why it's always me who have those garbages....
Old January 26, 2011, 02:47 PM
,ok,ok
Windows XP .. Prefetch? Doesn't exist.
Prefetch came with Vista and up.
Old January 26, 2011, 03:16 PM
lol, then dont disable that
whatever the equivalent of that is. its useless.
tweak xp or tune xp should prove eventful as utilities :)
gpu voltage tweaking.. gon_freecs Troubleshooting 3 February 1, 2011 08:01 AM
essential tools for computer tweaking Maculosa O/S's, Drivers & General Software 4 February 25, 2009 07:06 PM
OC Tweaking Spreadsheet misterlarry Overclocking, Tweaking and Benchmarking 0 September 3, 2008 04:44 PM
Tweaking Task Manager Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 8 February 6, 2008 11:13 PM
