Old January 18, 2011, 08:08 PM
botat29's Avatar
Default What VM software are you using
what VM software are you using and why ? I download the trial of VMware Workstation, but before spend $ 200 on it I want to explore other solution
Old January 18, 2011, 08:11 PM
VmBox and nothing else.
Really. Free and works well with every OS.
Old January 18, 2011, 08:19 PM
JD JD is offline
VMWare is probably the best performing solution though, but that's why it costs money. If you're relying on VM's for whatever reason, I'd probably stick to VMWare.
VirtualBox isn't too bad though and it is free which is a huge benefit. I think x64 support might be a bit iffy? Or maybe that's been fixed in recent versions.
Old January 18, 2011, 09:03 PM
Keywork's Avatar
Currently running virtualbox on my school laptop. I haven't had any issues thus far, even with 64 bit OS's.
Old January 18, 2011, 09:09 PM
VirtualBox runs fine with x64 OS in fact I have OS X running in a VM in a 64bit OS.
Old January 18, 2011, 09:28 PM
VirtualBox (Sun), VirtualPC and XP Mode (MSFT). They're good enough for my needs (testing, legacy support, running Linux tools and hardware without 64 bit drivers).
Old January 18, 2011, 10:45 PM
kingnubian's Avatar
VirtualBox.
You have got to try "Seamless" mode.
GOD Is Good
________________________________________
AMD Ryzen 1700 CPU
Asrock AB350 Pro 4 Motherboard
Corsair LPX 16GB (2x8GB) 3200Mhz
Adata SX8000 256GB NVME Drive
Crucial MX300 525GB M.2 Drive
EVGA GTX1080 FTW2
Corsair H105 AIO
Phanteks P400S Tempered Glass Edition
EVGA Supernova 650 G3
Old January 19, 2011, 06:24 AM
gingerbee's Avatar
Vmworkstation is what i run can it is wicked but like other said there are very good free alternatives. i just love vmstation cause it does anything and everything. my2cents and that's all folks
Old January 19, 2011, 08:02 AM
botat29's Avatar
I install the VMware Workstation last night and play with it , after I install the VirtualBOx and install a ubuntu on it, when I try to use my internet browser in Win 7, I was not able to go anywhere without installing VirtualBox, it's install a virtual network card that seems to be the problem. I know it’s probably just a setting to adjust. When I said I want try other before spent $ 200, it’s not that I’m looking for something free, I just want the one with less hassle, and of course don’t want to throw $ 200 to discover that I have better option.
I hope my point is understandable with my poor English.
Old January 19, 2011, 08:15 AM
Originally Posted by botat29 View Post
I install the VMware Workstation last night and play with it , after I install the VirtualBOx and install a ubuntu on it, when I try to use my internet browser in Win 7, I was not able to go anywhere without installing VirtualBox, it's install a virtual network card that seems to be the problem. I know itís probably just a setting to adjust. When I said I want try other before spent $ 200, itís not that Iím looking for something free, I just want the one with less hassle, and of course donít want to throw $ 200 to discover that I have better option.
There is no hassle with Virtualbox.
It installs a network driver so you can bridge or NAT your network connection to the virtual machine. You would have to uninstall or remove VirtualBox for this to be removed.
I've used most of the mainstream virtualization software out there and found that VirtualBox is quick and the easiest to setup and use.
Useful software for Rommel O/S's, Drivers & General Software 3 October 13, 2009 05:33 PM
Eq Software? aviduser Audio 2 May 6, 2009 10:55 AM
Tax Software misterlarry O/S's, Drivers & General Software 18 April 16, 2009 08:51 AM
Software WolfBane Networking 11 August 1, 2008 12:28 PM
