Old January 19, 2011, 09:46 AM
botat29's Avatar
I agree that VirtualBox look more simple, but I have another problem with it, my Ubuntu desktop is limited to 800 x 600, and I google how to fix it, and it's seems not to easy to do, ( Iím very newbie with linux, I want VM to learn it ) with VMware I can adjust my Ubuntu to 1920 x 1200 without make any change, please note than Iím using both virtual since only yesterday, so Iím far to be an expert. So for me until now, $ 200 seems to be a better choice. In the case of Ubuntu, I try with Windows Virtual PC, no success, I try with VMware we use with Folding, no success, I try with VirtualBox, easy install, but no adjustment of resolution and problem with my Windows 7 browsing, and with VMware Workstation, work right the first timeÖ So itís look that if I want it easy I pay $ 200, if I want something free, I have a learning curve. So I have to choice to spent money or timeÖ.
Old January 19, 2011, 09:51 AM
How to Increase Screen Resolution for Ubuntu in Virtual Box | eHow.com
Old January 19, 2011, 10:53 AM
NyteOwl's Avatar
VirtualBox mostly.
Obsolescence is just a lack of imagination.
Old January 19, 2011, 12:57 PM
misterd's Avatar
VMWare ESXi but it's a bare metal hypervisor meaning you need another pc around. Not something you install on top of your windows/apple/etc OS.
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old January 19, 2011, 02:40 PM
JD JD is offline
Originally Posted by Keywork View Post
Currently running virtualbox on my school laptop. I haven't had any issues thus far, even with 64 bit OS's.
Originally Posted by enaberif View Post
VirtualBox runs fine with x64 OS in fact I have OS X running in a VM in a 64bit OS.
I was actually talking about x64 Guest OS'es, not running VirtualBox in a x64 Host.
Old January 19, 2011, 02:53 PM
Yes that is how my OS X Guest is running.
Old January 19, 2011, 03:48 PM
VMWare at work, since they pay for it.
VirtualBox at home.
Old January 19, 2011, 11:06 PM
m1dget's Avatar
qemu O_O
"NIX is a classic example of security through obscurity because there is no real monetary reward for crackers and hackers to break Linix" -AkG
  #19 (permalink)
Old January 20, 2011, 07:03 AM
gingerbee's Avatar
since were on vm's here's sorry for the offtopic kinda i can not get any version of a osx to run on vmworkstation. i just want to try it out. since there so many mac lovers here. and before you ask yes i downloaded it cause i just want to try it out if it's good then i may buy one.
  #20 (permalink)
Old January 20, 2011, 07:33 AM
botat29's Avatar
ok let's talk about this one, if I understand well, you install it first on a hard Drive, and after you install the OS, it have it's own kernel, so it's not running over an OS, if so it's what i will prefer, as I want dedicate a build for it anyway, I can see they have a free download for the Sphere ESXi, but is it a trial or the full product, and I notice the Sphere is $ 1200 and up, what is the difference, of course with $ 1200 I will prefer build 2 more PC instead.
edit: wait, this is only good to install a server since you have to access it with a client on another pc ?
Useful software for Rommel O/S's, Drivers & General Software 3 October 13, 2009 05:33 PM
Eq Software? aviduser Audio 2 May 6, 2009 10:55 AM
Tax Software misterlarry O/S's, Drivers & General Software 18 April 16, 2009 08:51 AM
Software WolfBane Networking 11 August 1, 2008 12:28 PM
