Old October 24, 2006, 11:10 AM
alex
Guest
Posts: n/a
Smile How can we avoid winsock hijack in XP?
Want to know. How to make XP more secure. Too many malwares. All of them just want to hijack your computer.:cool:
Old December 9, 2006, 06:15 PM
sswilson's Avatar
You can try running Vmware or Virtual PC for all of your surfing needs. That way if you get hijacked you can just return the virtual PC back to it's original config to get rid of all the crap.
Or, you can also use a live Linux distro for your surfing needs and avoid the hassle all together. :)
Old December 9, 2006, 08:53 PM
Simple. Don't run Windows.
On the other hand and back to reality don't want issues with windows? Get a router, setup static ips, close off all ports and if the router is wireless shutdown the wireless system.
Install Avast/AVG for a free good anti-virus, spybot for the spyware and quit using Outlook Express and Internet Explorer and switch to Firefox and Thunderbird and call it a day... oh yah and don't install Sp2 :P
I have had a Windows install going now for almost a year still run SP1 and did my last Windows update dating back in ... march?
Old February 13, 2007, 12:49 AM
BALISTX's Avatar
I agree 100%. I am running the same setup Windows XP SP1 and haven't done a windows update in a year. Then again I don't use IE and I don't use Outlook Express. I use Firefox and Gmail.
Heatware
HWBOT
Old March 19, 2007, 01:48 PM
b1lk1's Avatar
I've never had a problem with SP2. Been running the same install for almost 14 months now. I do tons of surfing on IE and Firefox. Just don't open things you shouldn't and stay away from pron and warez sites.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old March 19, 2007, 02:20 PM
Babrbarossa's Avatar
You mean SP1?
Old March 19, 2007, 03:19 PM
b1lk1's Avatar
No, I meant SP2. Never saw any real reason to avoid it and I have no problems running it. In fact, I think people are being fearful for not running it, but that is purely my opinion. Most virus', hijacks and other bad things that get loaded onto a PC are due to the user either clicking on things they shouldn't, visiting bad places and just not taking any personal caution in general with using their PC. If you stay on reputable sites and don't clikc on the "You're the 10000000 visitor" flash links and the biggest evil enemy, Java, should always be disabled.
Avoid G84 and G86 until glitch fixed: Inquirer Babrbarossa Rumor Mill 3 April 2, 2007 08:46 PM
Computer routers face hijack risk: study sswilson Press Releases & Tech News 1 February 16, 2007 05:35 PM
