Old January 8, 2011, 09:27 PM
NyteOwl's Avatar
Question Unusual behavior from XP
I have an XP Pro SP3 install that has been very stable with no problems. Last fall I updated the firmware in my optical drive (hoping the new version would let me self region free. Since then every time XP starts, it "finds new hardware" (the cd/dvd drive) and asks for new drivers. If you cancel the requests, it gives you the usual warning about "new hardware can't be installed" but the drive appears to be fine in device manager and functions ok otherwise.
This past weekend I installed another HDD. XP is now seeking drivers for that as well at boot.
I have a flash drive it does the same thing to. That I wasn't concerned about as it's a specialized item.
I'm a but stumped. There are all kinds of suggestions if it can't find the drive, but it finds it (and uses it) just fine.
I'm a bit stumped.
Obsolescence is just a lack of imagination.
Old January 8, 2011, 09:32 PM
ZZLEE's Avatar
list out drives
go to sites fore drives seei f there are new drivers fore the drives fore XP SP 3 ?
Look fore new moutherbord chipset driver ?
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 8, 2011, 09:57 PM
NyteOwl's Avatar
Chipset drivers are up to date. You shouldn't need drivers for a Hard drive or a DVD drive.
The DVD drive is a Pioneer 218BK, the new HDD is a 1TB Seagate SATA2 (Current HDD is a pair of Seagate ES.2 SATA2 500GB in RAID-1).
Old January 8, 2011, 10:14 PM
bushwhacker's Avatar
how about uninstalling it from Device Manager - rebooting - run through installing new hardware?
Old January 9, 2011, 11:10 AM
Shadowmeph's Avatar
that is what I was going to suggest because this usually fixes the problem.
Old January 12, 2011, 06:24 PM
NyteOwl's Avatar
Tried that; same situation, prompts for drivers. I'm beginning to think there is one or more corrupoted registry entries somewhere.
Old January 13, 2011, 06:17 PM
Check the BIOS and see if you have a "Plug & Play OS" setting. Usually the setting doesn't make any difference either way but if it's not the default "No" then set it back to the default.
If it's corrupted registry, *backup* and then delete the following key:
hklm\system\currentcontrolset\enum\ide\cdrom{drive _model}
Windows should reinstall/rebuild everything on next boot (restore from backup if it doesn't). However, that key's default ACEs only allow the System to delete it, so you'll have to either use REGEDT32 to change the permission (administrators full), or run REGEDIT as System using SysInternals' PsExec (with the -s -i -d switches).
PsExec
Old January 14, 2011, 04:35 PM
NyteOwl's Avatar
Tried both of those already. No joy :(
Old January 14, 2011, 10:40 PM
Next up in the food chain maybe a corrupt inf folder/file or the registry setting pointing to the inf folder (hklm\software\microsoft\windows\currentversion\de vicepath), don't remember if XP support multiple devicepaths so rename then copy over from another system, extract from install CD or do a repair install.
Old January 19, 2011, 10:44 AM
NyteOwl's Avatar
Tried all that except a repair install. I avoid those except as last resorts due to unpleasant previous experiences ;)
Tags
drivers , xpsp3
Unusual noise from system Arundor Troubleshooting 9 April 7, 2010 09:27 AM
Strange behavior, I think it is the MoBo Z Overlord Troubleshooting 2 October 4, 2009 08:50 PM
VERY wierd behavior Toronto122 New Builds 25 April 3, 2009 03:50 PM
New here.. new build.. weird 4870x2 behavior. artemm Video Cards 8 March 14, 2009 05:51 PM
Strange Bittorent Behavior mo_bettah O/S's, Drivers & General Software 9 January 13, 2009 01:09 AM
