Old December 19, 2010, 05:46 PM
DRYJESUS's Avatar
Restricted Poster
So what am I supposed to do? :S
Originally Posted by sswilson View Post
Ninja'd!!!!!
I second the suggestion that you should probably be looking for a DNS issue.
Aside from that... removing and re-installing the network card should re-install the stack which might solve the issue as well.
Old December 19, 2010, 05:50 PM
go here : Ubuntu homepage | Ubuntu
and put it on a cd/dvd. go for 32 bits just in case.
keep it handy, it will be of use when the whole windows experience crashes or you just had enough. i always keep a cd either in the drive or very close by. close to no downtime for me
Old December 19, 2010, 05:54 PM
sswilson's Avatar
How to configure TCP/IP to use DNS in Windows XP
Old December 19, 2010, 05:56 PM
DRYJESUS's Avatar
Restricted Poster
Right now, they're at automatic. Are you guys telling me to do manual?
Old December 19, 2010, 06:02 PM
sswilson's Avatar
did you go into Advanced to verify that there wasn't anything in the DNS box?
After that.... I'd get the drivers for the network card, uninstall the current drivers, remove the network card from device manager, reboot and re-install the drivers when it picks up the card.
Old December 19, 2010, 06:11 PM
ZZLEE's Avatar
Up date ADOBE also
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old December 20, 2010, 09:12 AM
Originally Posted by DRYJESUS View Post
I've tried using Hijackthis and deleted some suspicious looking stuff, but it's still the same.
What kind of suspicious stuff?
On both the computer that works and the one that doesn't, open a command prompt (Start > Run/Search > cmd) and enter "nslookup www.symantec.com" at the C:> prompt (without quotes). Compare outputs. If they are different odds are you're dealing with DNS hijack malware.
Quickly check the systems network settings (Start > run > ncpa.cpl) and look for obvious changes, otherwise you'll need a AV scanner/cleaner.
AV scanner/cleaners that you can try are Malwarebyte, SuperAntiSpyware and Kaspersky Virus Removal Tool (big download):
Malwarebytes
SUPERAntiSpyware.com | Remove Malware | Remove Spyware - AntiMalware, AntiSpyware, AntiAdware!
Installation Guide of Kaspersky Virus Removal Tool 2010
If it was malware, I highly recommend that you check that Windows, Browsers, Flash, Adobe and Java are all patched up-to-date. Change passwords to all your online accounts -- email, websites, forums, etc.
Old December 20, 2010, 09:39 AM
Here is what I would do.
1) Make sure the system has a minimum of 1gb of ram (Yes this helps A LOT)
2) Use a good defrag like Auslogic on the drive
3) Run Malwarebytes and install a free AV like Microsoft Security Essentials
Those three things a lone can make a huge difference.
blocked Internet sites Gellidius O/S's, Drivers & General Software 1 August 24, 2009 03:41 PM
Microsoft Looks To Offer Multiple Browsers in European Versions of Windows 7 FiXT Press Releases & Tech News 11 July 27, 2009 03:15 PM
windows not loading???? Cadence Troubleshooting 2 January 18, 2009 11:58 PM
Help with CoD5 not loading maps D4ng3r Gaming 9 January 6, 2009 04:04 PM
Internet problems Lpfan4ever Troubleshooting 9 December 20, 2008 10:33 PM
