Old December 16, 2010, 12:03 AM
Blu's Avatar
Blu Blu is offline
Default Does XBMC automatically find out if it
Does XBMC find out if it's a tv series even if it's in a hard drive full of movies? Say I have a drive with 10 folders, 9 of which are movies and 1 is a tv series, will it find it and mark it as a tv series or not? Thanks.
Old December 16, 2010, 04:46 AM
You have to put your Tv shows in a differnt folder then add it as a new source and when you click set content make sure you use a Tv scraper.
Old December 16, 2010, 08:00 AM
lowfat's Avatar
Default s
This
You need a separate folder for TV shows and one for movies. Then when you add source you must select if it is tv shows or movies.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old December 16, 2010, 08:16 AM
Deeival's Avatar
This helped a lot with naming TV files properly: TV Shows (Video Library) - XBMC
Old December 16, 2010, 12:21 PM
Blu's Avatar
Blu Blu is offline
Ok, what if I have more then one hard drive with tv shows? I have about six 2TB full of movies and then about 1-2TB of TV shows, how would that work :)?
Old December 16, 2010, 12:34 PM
lowfat's Avatar
Add each source separately and make sure you set the content to the correct type of media.
Queen of Dreams WIP
Big Lian Li
Complete
Old December 16, 2010, 04:57 PM
You could mount your drives as "folders" as well. XBMC will scan through them like a tree no problem.
Annoying Win 7 Bug = Automatically disables Aero darren700 O/S's, Drivers & General Software 6 November 1, 2010 02:54 PM
EVGA Precision changes to different profile automatically? chouchou Troubleshooting 1 February 2, 2009 01:55 AM
(Vista) Disable/Enable network adaptor automatically zlojack O/S's, Drivers & General Software 4 November 20, 2008 11:12 AM
Feedback: Automatically retrieve titles miggs78 Suggestions & Feedback 0 October 22, 2008 10:49 AM
Sweepstakes? Are We ented automatically? lowfat Suggestions & Feedback 3 June 20, 2007 09:27 PM
