Old December 14, 2010, 12:22 PM
Blu's Avatar
Blu Blu is offline
Default Whats better for a HTPC
What software would you say is better for a HTPC?
XBMC or Media Browser media browser
I can't really think of what one I want to pick, alot of my HD movies are with DTS for audio with DXVA and some have AC3 audio so I don't really know what one has a better player and what not. Can you guys list some pro's and cons about the two? Thanks.
Old December 14, 2010, 12:37 PM
JD JD is online now
I run MediaPortal myself with the StreamedMP skin/plugin. Works great and no major complaints with it.
I'd say its just best to try them all and see what you like.
I'm not sure if XBMC has changed since I last used it, but with MediaPortal you can control which codecs you want to use. When I used XBMC, it lacked that feature. I like having full control over all the settings.
Old December 14, 2010, 12:48 PM
Blu's Avatar
Blu Blu is offline
I read lowfat's post about XBMC being able to use MPC which should allow it to play anything if need be, I will check out media portal as well. Does it download movie covers and information as well as tv shows and such as that is a major thing for me.
Old December 14, 2010, 12:54 PM
JD JD is online now
Well if you install StreamedMP it includes MovingPictures and TV Series plugins which do exactly that.
Download MediaPortal for free! - MEDIAPORTAL
StreamedMP - MEDIAPORTAL
Whats this worth? Fudd Rucker Water Cooling 17 February 24, 2010 09:25 AM
whats this kendallcschm CPU's and Motherboards 6 December 22, 2009 10:53 AM
Whats the best MB i can get for ??? WolfBane CPU's and Motherboards 12 May 29, 2009 05:31 PM
Whats Better trayton CPU's and Motherboards 4 May 1, 2009 08:16 PM
whats this mean ? Jim CPU's and Motherboards 8 July 25, 2007 05:39 AM
