Old December 4, 2010, 09:54 AM
CMetaphor's Avatar
Quadfather
Default Dedicated HTPC OS
Was just wondering what everyone uses for their dedicated HTPC OS'. I have a few requirements, but am totally flexible otherwise on what to use.
Requirements:
- Must be able to use the XP Media Center Remote/IR combo (already have)
- Connection to Windows shared drives for streaming of all media.
- Must utilize hardware acceleration from an AMD chipset (4200) for High Def. (The CPU many not be able to handle this alone - going passive low-power CPU)
Ideas thus far:
1- Windows 7 - boot directly to Media Center. Might be the simplest option, as I know all the hardware and remote will work without a hitch. It is, however, the slowest IMO so im uncertain.
2- Windows 7 - XBMC. Not sure about remote compatibility with XBMC, but it seems promising. Fast as well.
3- XBMC (Installed on a usb key/SD card) Standalone XBMC seems the lightest and possibly the fastest way to go, but I have no idea if XBMC will properly recognize and use the power the AMD integrated GPU to handle the high def stuff.
4- MythBuntu - Haven't seen it used in a while, but apparently its still out there and popular.
5- ???
So that's where I'm at right now. I'm kinda liking option #3 the best, as it saves me a hard drive, but I'd also like to know your opinions and suggestions. Thanks all!
Old December 4, 2010, 09:57 AM
Arinoth's Avatar
I use Windows 7 - XBMC. The remote i use is my Samsung Galaxy S as all android phones have a free xbmc app that turns them into remotes for xbmc if you are on the same network.
My htpc/server uses the hd4200 for decoding and has no issues under windows 7 running XBMC doing even 1080p playback at all.
Old December 4, 2010, 10:07 AM
CMetaphor's Avatar
Quadfather
Thanks for the feedback! Windows 7 w/ XBMC seems to be the new "best bet" because of this little tidbit I found when rummaging through the XMBC wiki page:
"Note however that the primary dependency is the CPU, because XBMC uses software decoding for all video streams."
AND
"ATI/AMD Avivo Technology uses pixel shaders to assist in decoding the video. So far only ATI/AMD closed source binary device driver for Microsoft Windows support this Avivo Technology."
So XBMC Live is out (damn, need to buy another hard drive now). What about MythUbuntu? MythTV for windows? Media Center?
JD JD is offline
I run Windows 7 too, though I use MediaPortal over XBMC.
Old December 4, 2010, 10:46 AM
odis172's Avatar
If you end up using windows, you might want to check out EventGhost. You can use it to associate any device that outputs IR signals to a windows command. That way you can map any remote as well as many other devices.
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old December 4, 2010, 10:55 AM
Perineum's Avatar
I'm using Windows7 with Media Center and the mymovies.dk plugin. It works pretty damn good, but I can't compare it to XBMC as I haven't bothered to try it out yet.
Old December 4, 2010, 01:04 PM
Supergrover's Avatar
Same 7 with Media center and plug ins, I am going to have to try out XBMC but haven't ever got around to it yet.
I think I might just make it my "Sunday" project and see what all the fuss is over. What plug ins would I want to be installing for XBMC?
R.I.P.
Old December 4, 2010, 02:31 PM
ipaine's Avatar
That is what I am using as well. I took an early look at XBMC but liked the look of MediaPortal better. I use it with the my movies and my tv series plugins. This works good for my 450ish movies and 3500 or so tv episodes.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old December 4, 2010, 10:04 PM
JD JD is offline
Yeah I run the StreamedMP skin which includes all the major plugins. Back when I tried XBMC I found it's settings weren't advanced enough for my liking. Probably far different today than it was when I tried it though.
Old December 4, 2010, 11:46 PM
I use MP/SteamedMP as well, love it.
As for the OP, Windows 7 + Mediaportal.
Dedicated physX GPU MarkOne Video Cards 1 January 18, 2010 04:27 PM
CoDMW2 no dedicated servers Shade340 Gaming 51 November 12, 2009 05:33 AM
Dedicated PhysX... Shall i bother ? JORD4N Video Cards 11 November 1, 2009 05:50 PM
GPU for dedicated HTPC use. Empty_Quarter Video Cards 4 January 1, 2009 12:47 PM
dedicated server FC2 nasrott Gaming 0 October 29, 2008 03:20 AM
