Old November 24, 2010, 05:10 AM
KaptCrunch's Avatar
Originally Posted by CTA View Post
reset = push and hold into button at the little hole with your paper clip or something... its easy way to fix but you might have to add or something (such as forward port)
congifure = long way to explore the problem... upgrade, delete, add, etc...
fireware = get the firmware from the offical site... AND read the instruction very very carefully...
first record all info settings of router then reset
Old November 24, 2010, 10:55 AM
Shadowmeph's Avatar
Or a DNS site like https://www.opendns.com/ could be blocking it that is of course if you are signed up to one
Old November 24, 2010, 05:42 PM
KRAFTIG's Avatar
Did the reset = Nothing
Configure = Above my knowledge base
Fireware = Updated. Did nothing.
Old November 24, 2010, 06:25 PM
any chance you could load a live cd ubuntu or whichever you prefer and try from the computer that is affected? :) that will clear out the software issue. which it probably is.
Old November 25, 2010, 02:12 AM
KRAFTIG's Avatar
What do mean by live?
Old November 25, 2010, 02:28 AM
Linux live cd loads a temporary OS to ram, it doesn't copy anything to the hard drive.
It won't change anything to your system.
Old November 25, 2010, 02:50 AM
yup. just in case unplug all hdds, if you have doubts.
also its good to have in case your hdd dies, or your os becomes corrupt and you need to check email etc within the next 5 mins.
Old November 25, 2010, 04:07 PM
KRAFTIG's Avatar
Thanks.
  #19 (permalink)
Old November 25, 2010, 06:34 PM
headsh0t's Avatar
Guys, it's obviously not anything on his computer if it works fine with the modem directly connected to the computer....
  #20 (permalink)
Old November 25, 2010, 08:08 PM
Hmm I had a similar issue twice (also on Rogers) where all web pages were taking a long time to load. The first time, I solved it by changing the Ethernet cables at the back of my router and modem. The second time, which just happened about a week ago, I fixed by unplugging (the power for) BOTH the modem and router for about 10 seconds, then plugging them both back in. Essentially when this happens the first thing I do is try to reset everything I can about the connection.
If that doesn't work, you can also try changing your DNS servers on the router - I use OpenDNS because I've had laggy / spotty web page lookups with whatever DNS Rogers gives me.
Back in the Windows XP days I'd also do a hosts file reset to solve issues like this, ( http://en.wikipedia.org/wiki/Hosts_(file) ) but I haven't done that in years.
website access to pandora.com Mark Off Topic 8 April 15, 2010 09:40 AM
Cannot access Private Messages Digikid Suggestions & Feedback 23 March 2, 2009 08:05 AM
Remotly access the tv card elec999 HTPC Systems & Software 3 December 4, 2008 03:09 PM
Cannot access certain websites, intermittent website access chrisk Networking 16 November 30, 2008 12:24 PM
Raid Access failure Eagle Eye Storage 9 November 14, 2008 05:05 PM
