Old November 22, 2010, 03:45 PM
xMechanixxx's Avatar
Default Linked List Segmentation Fault, Please Help!
Hey everyone, I'm writing a program as an assignment for school and I though I had worked out all the bugs until I decided to call my copy constructor. The program is interactive (CLI) which basically has two moduals: a .h and .cpp file for the LList class and a .h and .cpp file for the structure of the program and also a 3rd cpp file just for main(). It is suppose to be a program for a hydropower engineering company (fake company) in which the LList nodes hold data for their annual water flow in a river(year and flow). Here is some insight on the class:
Code:
//list.h
struct ListItem {
  int year;
  double flow;
struct Node {
  ListItem item;
  Node *next;
class FlowList {
public:
  FlowList();
  // PROMISES: Creates empty list
  FlowList(const FlowList& source);
    // REQUIRES: source refers to an existing List object
    // PROMISES: create the copy of source
  ~FlowList();
    // PROMISES: Destroys an existing list.
  FlowList& operator =(const FlowList& rhs);
  // REQUIRES: rhs refers to an existing FlowList object
  // PROMISES: the left hand side object becomes the copy of rhs
//....Other member functions
private:
  // always points to the first node in the list.
  Node *headM;
  // Initially is set to NULL, but it may point to any node.
  Node *cursorM;
  //For node manipulation within interactive CLI
  void copy(const FlowList& source);
  void destroy();
I belive the memory leak or collision is taking place somewhere within the copy function but cant pin point where.
Code:
//list.cpp
FlowList::FlowList() : headM(0), cursorM(0) {}
FlowList::FlowList(const FlowList& source)
  copy(source);
FlowList::~FlowList()
  destroy();
FlowList& FlowList::operator =(const FlowList& rhs)
  if (this != &rhs)
    destroy();
    copy(rhs);
  return (*this);
//...more function definitions
void FlowList::copy(const FlowList& source)
  if (source.headM == NULL)
    headM = NULL;
    cursorM = NULL;
    return;
  Node* new_node = new Node;
  assert(new_node);
  new_node->item.year = source.headM->item.year;
  new_node->item.flow = source.headM->item.flow;
  new_node->next = NULL;
  headM = new_node;
  Node* thisptr = new_node;
  for(Node* srcptr = source.headM->next; srcptr != NULL; srcptr = srcptr->next)
    assert(new_node);
    new_node->item.year = srcptr->item.year;
    new_node->item.flow = srcptr->item.flow;
    thisptr->next = new_node;
    thisptr = thisptr->next;
void FlowList::destroy()
  Node* ptr = headM;
  Node* post = headM->next;
  while (ptr != NULL)
    delete ptr;
    ptr = post;
    if (post)
      post = ptr->next;
  headM = NULL;
The program works fine if I create a FlowList object, fill it with data from a .dat file; i can then manipulate the data within the program (display, perform calculations, add to the list, remove from list and save data to file) but program crashes (segmentation fault) if I create another FlowList object (within main.cpp).
Sorry for the lengthy post but any help would be really appreciated.
Old November 23, 2010, 06:23 PM
You've messed in the destructor of the FlowList.
Node* ptr = headM;
while (ptr != NULL)
delete ptr;
ptr = post;
if (post)
post = ptr->next;
headM = NULL;
You're assigning *post with unchecked headM and get a segmentation fault because headM could be NULL.
And it is NULL if you just declare a variable and don't use it.
This simple one-line main will get you a segmentation fault.
Code:
int main() { FlowList a; return 0; }
You'd better have it like this:
Code:
  Node* ptr = headM;
  Node* post;
  while (ptr != NULL)
    post = ptr->next;
    delete ptr;
    ptr = post;
  headM = NULL;
Old November 23, 2010, 08:43 PM
Thanks for the reply but the gents over at stackoverflow got back a bit quicker. They pointed out the same thing as you so I went ahead and modified it to
Code:
  cursorM = NULL;
  if (headM == NULL)
    return;
  Node* ptr = headM;
  while (ptr != NULL)
    delete ptr;
    ptr = post;
    if (post)
      post = ptr->next;
  headM = NULL;
Your way does look a bit cleaner than my brute force method tho. Thanks anyway
Old November 23, 2010, 09:32 PM
ZZLEE's Avatar
one off my uncles does this type off thing. If need some real data look of flow rates on any river in Ontario on Enviorment Canada I think.
Edit: Link http://www.google.ca/url?sa=t&source...v9GjLg&cad=rja
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
EVGA 680i fault codes?? catguy Troubleshooting 7 September 22, 2009 05:40 PM
is 520W enough? (it's the fault of the Q6600) nico Power Supplies 5 July 26, 2007 11:13 AM
