<~----> Vista64bit/2puters/1 serial? - Hardware Canucks
Old December 23, 2007, 01:19 PM
Default Vista64bit/2puters/1 serial?
My brother just purchased a computer and recieved both vista 64 bit and 32 bits system disks with it. He has the 64 bit version installed. Can I also install the 64 bit version on my computer aswell, using the key they provided, even though he has regestered it?
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old December 23, 2007, 01:50 PM
Supergrover's Avatar
Nope, 1 key needed per computer.
R.I.P.
Old December 23, 2007, 05:18 PM
MpG's Avatar
MpG MpG is offline
If the OS was installed with an OEM key, the keys on both disks are technically unused, right? Maybe you can convince him to settle for 32-bit if he ever has to reinstall...
Old December 23, 2007, 06:28 PM
b1lk1's Avatar
Microsoft will lock one of you guys out of running your OS if you do that.
MY HEATWARE
Old December 24, 2007, 09:03 AM
well, i thought id ask anyways.... the system was purchased from a computer shop, it was built from scratch and im not sure if the key is OEM or not. I wont screw him over, so i wont mess with it... but isnt it kinda dumb that you cant use it on the 2 different computers?? I have 3 here.... if I want to but the vista, id have to buy 3 disk for my own computers?? that crazy..
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old January 6, 2008, 07:46 AM
Talking
Well the only way you could run it to try it with your bros permission is use the
no cd key entered install
just defer the key entry.
you can get all the downloads the pleasure the pain
You try before you buy around 3 20 to 30 day renewals allowed
not that bad.
You could then enter a valid key taken off what you have bought as long as it matches
heck XP 64 wasn't it once 90 day trial -+
Cambridge,ON
MSI Z77 M Power/Bios17.8
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Antec P280
Intel Speed Demon Equipped
using Prime 95 27.9
