Old October 17, 2010, 08:03 PM
Prolab's Avatar
Default Win 7 HP + combined storage pool
Hey Guys/Girls,
I searched but it came up only for WHS. Also im planning to get the Asus Crosshair IV in a few months, so everything will be moved to that mobo. Unfortunately, searching using the same questions comes up as only on RAID or JBOD is supported under the new mobo.
I dont want to use mobo raid.
Anyhow, my WHS server has currently have 2.1 TB of data out of 4 TB. My Gaming rig has one (2 TB) hd. Im planning to get another 2 TB and i was wondering if there's a way i can pool two (2 TB) under one partition on Win 7?
Or a 3rd party solution is needed?
Gaming Rig:
-Swiffy 655 & 360 rad, 360 XSPC Rad, HK Supreme HF, EK D5 top rev.2, AMD BE 1100T OC to 4.07 ghz, 16 GB G.SKIL F3-12800CL9Q-16GBXL, Asus Crosshair V, (2) XFX 6950 w/ XPSC WB, Crucial M4 128GB & 120 GB Vertex 2 EXT, (4) 2 TB WD Green Drive, Corsair AX1200, Win 7 Pro 64-bit
Server Rig
-AMD Athlon II 245 stock, Asus Mobo, 2 GB DDR2 Kingston, WHS, 500 GB WD Black, (2) 2 TB WD Green, (2) 2 TB Seagate HD, (1) Samsung 2 TB F4, Fractal Design R3, Antec 650 watt PS
Old October 18, 2010, 09:30 AM
botat29's Avatar
Originally Posted by Prolab View Post
... i was wondering if there's a way i can pool two (2 TB) under one partition on Win 7?...
With windows 7 you can set your drive as dynamic drive, it will allow you to make a volume of 4 tb with 2 x2tb drives . But you will need a dam god backup in case 1 drive fail.
Old October 20, 2010, 10:29 AM
Prolab's Avatar
Oh ok, thanks for the heads up.
Gaming Rig:
Server Rig
Denim and Computers...something that shouldn't be combined aviduser Cases 15 December 22, 2009 10:25 AM
HWC Hockey Pool!!!! Eldonko Hockey 271 September 28, 2009 09:57 AM
combined wireless router w/ADSL modem Mr. Friendly Networking 5 April 29, 2009 03:07 PM
Can I fold on a GT200 and G92 combined rigs? zlojack HardwareCanucks F@H Team 6 March 12, 2009 10:38 AM
basic(?) psu question - dual rail combined ratings ccm001 Power Supplies 7 March 26, 2008 04:58 AM
