Installing OS on a netbook
Hey all, I had windows 7 installed on my netbook (acer aod-150?.... something like that) I wanted to put windows XP back on it, but I couldn't get it to work via usb drive (tried all the boot from usb to install xp instructions online)
so my plan was to hook the hdd up to another laptop, start the windows install, then pull it when it rebooted and put it back in the netbook. As it would have preloaded the install files and wouldn't be running from the CD at that point.
However I ran into a few BSOD's on both the netbook and the laptop i was prepping the hdd on. I determined they were due to power/sata settings on the laptop that conflicted with the XP install files, I was able to disable those settings in the BIOS and run the install successfully, then switched the hdd back to the netbook ...
then i ran into the problem that the BIOS on the netbook is so basic that I don't have the option to disable those functions, so it still gets a BSOD.
I'm a bit stumped at this point. I suppose I could install windows 7 again the same way and it would work, but I was pretty set on having XP on this computer, as it really needs 2gigs of ram to run 7 efficiently.
Any thoughts???
