-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Anyone having problems with Win7 installing the latest updates (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/36665-anyone-having-problems-win7-installing-latest-updates.html)
KRAFTIG September 29, 2010 02:22 PM
Last night my system automatically downloaded the latest new updates available from MS, three in total - See below. When the system reboots the OS is stating the system is configuring the updates. The percent bar stays at 0% and after 5 minutes it states the update was a failure and is resorting back to old setting. What is the problem. I want to fix this as I like these updates to continue, plus the system will download the same three updates again and try to install the next time I reboot the system. Thanks.
Update for Internet Explorer 8 Compatibility View List for Windows 7 for x64-based Systems (KB2362765)
Download size: 27 KB
You may need to restart your computer for this update to take effect.
Update type: Recommended
This Compatibility View List update helps make Web sites that are designed for older browsers look better in Internet Explorer 8. When users install Internet Explorer 8, they will be given a choice about opting-in to a list of sites that should be displayed in Compatibility View. After you install this item, you may have to restart Internet Explorer.
More information:
Description of the Compatibility View list in Windows Internet Explorer 8
Help and Support:
A Compatibility View list update is available for Windows Internet Explorer 8: September 28, 2010
Update for Windows 7 for x64-based Systems (KB2158563)
Download size: 575 KB
Update type: Important
Install this update to resolve issues caused by revised daylight saving time and time zone laws in several countries. This update enables your computer to automatically adjust the computer clock on the correct date in 2010. After you install this item, you may have to restart your computer.
More information:
September 2010 cumulative time zone update for Windows operating systems
Help and Support:
Microsoft Support
Update for Windows 7 for x64-based Systems (KB979538)
Download size: 208 KB
Install this update to prevent unexpected shutdowns or bluescreens when you are using a USB video device. After you install this item, you may have to restart your computer.
More information:
"Stop 0x0000007E" or "Stop 0x00000050" Stop error message in Windows 7 or Windows Server 2008 R2
Help and Support:
Microsoft Support
3.0charlie September 29, 2010 02:25 PM
All my rigs updated properly yesterday and today. Try to install an update one at a time.
KRAFTIG September 29, 2010 02:29 PM
Thanks I`ll that that now.
KRAFTIG September 29, 2010 02:37 PM
It worked! Thank you 3.0charlie!!
3.0charlie September 29, 2010 02:42 PM
My pleasure.
