Old December 11, 2007, 08:06 AM
donimo's Avatar
Default HELP! Windows won't load, BSOD!
I tried a VeRY mild overclock (375fsb, 333 stock), but the ram didn't like it I guess (I have done this O/C before with the old ram).
Rebooted during the vista load screen, but now it just loops and loops, giving me the BSOD.
Won't load even off the vista DVD (or xp cd for that matter).
If I detach the c: drive physically it loads off the dvd, but if I have it attached in any way it locks up.
It lockcs up on "crcdisk" if I do the bootlog, and "ntfs.sys" if I use the xp cd.
Everything I have read, and all onscreen help says to load up the vista dvd and do chkdsk /f, but how do I do that if the damn dvd keeps loading off the Hard drive with the problem?
anyone have a ntfs compatible chkdsk I can boot off of?
I have tried the ultimate boot cd, but cant get it to work (the chkdsk prog is in german....)
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old December 11, 2007, 08:17 AM
donimo's Avatar
this is problem here:
not booting (not even Vista Install DVD): crcdisk.sys - TechNet Forums
Old December 11, 2007, 08:25 AM
Shadowmeph's Avatar
Did you set everything back to default after your OC failure?
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old December 11, 2007, 08:39 AM
donimo's Avatar
yes, memest and all the other tests show the hardware as being ok
no amount of BIOS fiddling helped
Old December 11, 2007, 08:50 AM
donimo's Avatar
STOP: 0X00000024 (0X001904AB, 0X8658F89C, 0X8658F5CC, 0X8588448F)
**** NTFS.SYS ADDRESS BAS AT 8586A000 DATESTAMP 4549ACEB
THIS IS WITH THE VISTA DISK, IT ALSO TELLS ME TO RUN CHKDSK/F BUT HOW THE HELL DO YOU DO THAT IF THE STUPID DISK WONT LOAD? thanks vista
sorry about the caps
Old December 11, 2007, 09:26 AM
"Quote This..."
Is it that exact same message every time?
Old December 11, 2007, 09:27 AM
donimo's Avatar
yes
if I unhook the drive, it loads the dvd just fine, but then I cant run chkdsk because the stupid drive isnt hooked up, argh!
is there a way to force it to load on the 2nd hard drive and not the one with the problem?
Old December 11, 2007, 10:19 AM
qwerty's Avatar
I haven't played with Vista as of yet but you on previous Windows versons you cannot simply boot to another hard disk on your system without that specific windows version being installed on such.
If I had an Xp CD I might be tempted to do the same thing on Xp to see if the same problem was on Xp as it appears to on Vista. At least then you can start to eliminate problems and/or solutions.
EDIT - Yeah I am one of those wierdos that believes that Windows 2000 pro is one of the best OS's they ever built...lol.
Old December 11, 2007, 10:32 AM
donimo's Avatar
xp disk does the same thing with a slightly different BSOD, still refers to NTFS.sys though...
ARRGH, WTF!
Anybody have a checkdsk util I can boot off off a cd?
Old December 11, 2007, 10:36 AM
Question:
Are these sata drives or are they ide drives?
If they are sata are they setup as AHCI or standard SATA?
Manually load files into RAM? Thund3rball RAM 6 February 4, 2008 11:52 AM
BSOD with 4gbs of Ram vintank RAM 14 February 2, 2008 12:20 AM
BSOD while playing COD4 3 times in a row zlojack Troubleshooting 31 January 21, 2008 11:38 PM
BSOD from iTunes? :| curtispan Troubleshooting 3 January 5, 2008 03:23 AM
My Computer takes 4 ever to load kcksteve Troubleshooting 13 October 16, 2007 03:50 PM
