Old September 17, 2010, 04:24 PM
I like MyDefrag (was known as JKDefrag), I also like to have spybot, and Tweaknow Winsecret to ''pimp''my windows a lil -.- As I hate to reinstall, I try to keep it as clean as possible.
Old September 17, 2010, 05:06 PM
if you do(and you shoud) use the above, set it to screen saver(unless you fold). daily usage. then once a week doa monthly if you use it a lot, else do the monthly every once in a blue moon. takes a whole lot longer to finish. best defragger ive used to date.
Old September 18, 2010, 07:35 AM
bushwhacker's Avatar
some for me are:
ImgBurn
Foobar 2000
VLC
7-Zip
Foxit Reader
Mozilla Thunderbird
JAlbum lets you share your photos in spectacular web albums and turn them into book store quality books
Convert for Windows is a free and easy to use unit conversion program that will convert the most popular units of distance, temperature, volume, time, speed, mass, power, density, pressure, energy and many others, including the ability to create custom conversions!
Filezilla the free FTP solution. Both a client and a server are available.
TightVNC is a free remote control software package. With TightVNC, you can see the desktop of a remote machine and control it with your local mouse and keyboard, just like you would do it sitting in the front of that computer.
Old September 18, 2010, 09:37 AM
grinder's Avatar
good list of apps!!! i'll throw one of mine into the hat:
iso recorder
Old September 18, 2010, 10:54 AM
sswilson's Avatar
Personally, I don't install an awful lot of extras outside of those required for OC.
CPU-Z
EVGA Precision
Motherboard monitoring software (just to compare recorded temps with coretemp/realtemp)
Coretemp / Realtemp (depending on intel/amd)
OCCT (medium range stress test)
Prime95 (8 hr+ stress test)
SuperPi (quick stability check)
After that, it's a few apps
OpenOffice
Paint.Net
FastStone Image Viewer (screen caps/resize)
And I've been leaning towards Microsoft Security Essentials lately just because it's free and supported by Microsoft.
Old September 18, 2010, 05:44 PM
r0bc's Avatar
I've been using image resizer for resizing pics and I really like the newer MSE beta, but liked the old MSE to though.
Image Resizer Powertoy Clone for Windows
Old September 18, 2010, 06:27 PM
irfanview
since the beginning. speedfan as well. couple more, mem fails me. winrar of course.
Old September 18, 2010, 09:41 PM
grinder's Avatar
consider 7zip over winrar, no nagging register screens, it's a thinner applet, and comes in 64 bit flavor
