Old September 13, 2010, 01:40 PM
It was the drivers I tried before from AMD. Their 7 zip files give you a bunch of subfolders and I must have used the wrong install. That and a codec and I'm all set. Just need to try this DriveImage XML and get backup tested, cause my Ghost 8.0 disc doesn't seem to install. Then I'll finally load appls. Appreciate all the help jdrom17, zoob, KaptCrunch, et al. Cheers.
tunnel-bus >>>> sky/subtrain and bus CTA Off Topic 5 August 20, 2010 10:12 AM
what is bus speed kuziwk CPU's and Motherboards 7 January 20, 2010 12:51 PM
DRAM bus voltage Dogger1 Troubleshooting 13 February 18, 2009 09:12 AM
Bus driver blindly follows GPS, tries to fit 12-foot bus into 9-foot tunnel stoanee Off Topic 8 April 21, 2008 08:10 PM
Dropping BUS speed from within an OS 21YearsCanadian Overclocking, Tweaking and Benchmarking 2 March 28, 2007 02:44 PM
