Old September 11, 2010, 08:18 PM
thanks guys I think I'm just gonna re-install everything =\ good point on the clean up, only thing that bothers me is if I re-install Steam, will it detect that all the games are already there? I have Steam application and other files on the same HDD
CPU:Intel i5 6600k - Corsair H110
GPU:EVGA GTX980Ti FTW Edition
HDD:250GB Samsung Evo 850 SSD, 3TB WD Black
MOBO:Asus Z-170 Deluxe
RAM:G.Skill Ripjaws V F4 2800mhz 16GB
PSU:Silverstone 950W
CASE:Silvertstone TJ07
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
Old September 11, 2010, 08:19 PM
You don't have to install Steam. Just copy over your entire directory and run Steam.exe once you've reinstalled. It will automatically make any necessary registry entries, and it will detect all the games you already have downloaded.
Old September 11, 2010, 08:24 PM
JD JD is offline
Does it really? I usually just copy the steamapps folder but re-install Steam itself whenever I reformat. Good to know.
Old September 11, 2010, 08:38 PM
gingerbee's Avatar
or you can just go through and manually edit out the crap form reg it's real easy if you know what your doing and ya zero's right had to do this for a client/friend a few months back
Old September 11, 2010, 08:44 PM
lol I'll look through the reg edit and see if I can figure out since I just got to export it. The only thing installed on my raptor drive that I'm switching out is OS and drivers.
Moving OS from HDD to SSD artistpavel Storage 29 November 20, 2010 02:32 PM
ssd vs hdd opinions thatguy7 Storage 32 May 18, 2010 11:56 AM
Why use a SSD Or Fast HDD? TokeR New Builds 27 December 10, 2009 12:36 PM
Question(s) about RAID, HDD's, and SSD'S AmuseMe Storage 28 September 6, 2009 10:22 AM
RAID 0 in SSD or HDD? Chintu92 Storage 16 August 28, 2009 02:29 PM
