Old August 11, 2010, 01:31 PM
Default PC Downloads Without me Knowing!
Hey please I need some help. I finally found out why my data usage is being used up all the time.
If I watch a video on youtube and then press back or quit it... sometimes the data from the video is still being downloaded. I found this out by looking at my firewall....the recieved bytes keeps downloading.
The more I go back the more higher my data will be loading at faster speeds. I look at my data usage and 300 mb get downloaded in like 3 minutes or less. (I have fast 25Mbps internet) This is a big problem because of my speed. To fix this problem temproarly i have to disable my ethernet card thing and reanable it. Then the downloading stops.
what could be the problem?
I am currently running virus scan and i found 4 infected but i really dont think its a virus. I think its some sort of bug.
Happens in internet explorer and Firefox...
Build: i7-920, EVGA GTX 285, XFX X58i Extreme Edition , 2GB x 3 DDR3 - Patriot Viper, ThermalTake M9 V1000series, Ultra LSP 650w, Western Digital 500GB @7200rpm,
Old August 11, 2010, 01:34 PM
sswilson's Avatar
Do you use any kind of download manager, or possibly one of those Youtube video converters?
Old August 11, 2010, 02:39 PM
no. I dont know why it happens. I have been using google chrome and it reduces the chances of it downloading without me actually watching the video.
I always have to keep an eye on my firewall to make sure nothing is being downloaded.
I am sure it has to be the videos because this only happens when I watch youtube or any other videos like dialymotion.com and when i press back or click a new video.
I dont think this happens to my other pc's.
antivirus has found 9 infected files now.. i really hope its a virus.
Old August 11, 2010, 02:41 PM
When I mean downloading.. i dont mean like saving to the computer. Just streaming but the data does get downloaded maybe to cache.
Old August 11, 2010, 03:04 PM
Make your browser cache size less than 20mb and see if that helps.
Old August 11, 2010, 03:05 PM
sswilson's Avatar
Yeah it would normally go into cache. What I'm wondering is if "normal" operation would be for any media player to anticipate wanting to play the whole file and downloading it in total for cache purposes.
Old August 11, 2010, 03:06 PM
m1dget's Avatar
Is the problem only when you are watching video with your browser?
If not, I'm going to assume that you don't have a wireless network attached to your router/one of your computer running on your network that has access to your gateway?
If you don't have a wireless AP well get 'wireshark', run it on your main/possibly only NIC, post results and then we will be able to help you better. It may be windows screwing up big time also; I've seen some weird crap going on with the network stack of that creature o.O
"NIX is a classic example of security through obscurity because there is no real monetary reward for crackers and hackers to break Linix" -AkG
Old August 11, 2010, 03:10 PM
sswilson's Avatar
If you right click on a youtube video there is the option to "stop download". There is also the option to adjust how large of a file size youtube is allowed to store. I'd try adjusting that down.
Old August 11, 2010, 03:17 PM
sswilson's Avatar
You can also check here for "peer assisted network" settings in flash player to disable it. When the hell did Flash sneak in a freaking P2P client / functionality?!?!?!?!?!
Adobe - Flash Player : Settings Manager - Peer Assisted Networking Settings panel
How many other freaking utilities these days are using my f'ing bandwidth without my consent, or if they aren't using it yet, how many have the option built into them!?!?!?!?
Old August 11, 2010, 03:22 PM
holy shit... i had a long list in there :O bastards
Fan Hole & Radiator Template Downloads Mnpctech Guides & How-to's 6 October 30, 2009 03:07 AM
x-fi prelude patch 1.0 gone from driver downloads moondogg Audio 4 April 29, 2008 03:26 PM
