Old July 28, 2010, 08:01 AM
Can someone please help me to use dban? Ive found info to wipe the whole drive, but havent found anything really helpful about erasing only the first 512 bytes. And after erasing the MBR and partition tables, will I be able to run windows to format and partition the drive as usual? Can somebody guide me through this?
Old July 28, 2010, 09:04 AM
bissa's Avatar
if you have deleted the MBR, you have deleted the first 512 bytes at the beginning of the drive, you have done basically the same thing as a quick format and the windows boot disc should boot now if the problem was that it was finding a windows install.
Strong like hummingbird, swift like oak.
I'm sorry july, I couldn't see you behind all that feruary.
Old July 28, 2010, 09:26 AM
Forgive me if my post was unclear. I haven't deleted anything yet, but as another poster stated, I don't have to do a full wipe, just the first 512 bytes, so if i can do that and save the time i would rather go with that option. Or am i just not making any sense lol.
Old July 29, 2010, 05:09 AM
Varroa's Avatar
Boot from this:
AVG Antivirus and Security Software - AVG Rescue CD
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old July 29, 2010, 06:10 AM
Alas the problem is solved, windows is back and updated. I put the ubcd in and booted but picked the wrong thing and had to restart but instead of leaving the ubcd in the drive i tried the xpcd again and it booted. Drive successfully formatted and partitioned without having to use dban. Thanks for all the help guys.
Old Spice Viral Marketing FiXT Off Topic 13 July 16, 2010 10:27 AM
Help with RAM problem plz! Plasma RAM 4 December 7, 2009 10:48 PM
AROUND THE NET ( viral video's) badatcards Off Topic 61 November 14, 2009 01:00 PM
8800 gt problem in.....plz and thx rob123 Video Cards 7 April 24, 2008 07:32 PM
One nasty landlord:) cdn_Madrach Off Topic 5 April 19, 2007 05:25 AM
