Old July 1, 2010, 09:09 AM
Default intelburntest + furmark problem
I can't seem to run both at the same time without furmark dropping to 30fps and causing the gpu to barely be loaded and temps drop. I could run both at the same time if I set intelburntest to 3 threads but at auto, it would cause the gpu to drop temps but cpu still loaded. How do I use intelburntest and furmark at same time while both being loaded?
Old July 1, 2010, 10:38 AM
gingerbee's Avatar
i would not use them at the same time 1 is to test cpu overclock the other is too overclock your gpu why would you run them together. run them separate well doing your testing once tested and stable move to the next thing you want to overclock.
of course it's gonna drop frams the cpu is running the whole show well gpu is doing only visual stuff only. no point at all to run both they stress completely different things
Old July 1, 2010, 10:52 AM
I was trying to see if my psu will stand my gpu + cpu and i also wanted it to heat up so i can warm up my hands but it didn't
Old July 1, 2010, 03:17 PM
headsh0t's Avatar
When you're using intel burn test it is using 100% of your CPU, furmark doesn't get any CPU cycles. If you want to stress both at the same time run Prime95 on the CPU while using Furmark.
Old July 1, 2010, 03:23 PM
gingerbee's Avatar
ok at least what you wanted to do makes sense now .
FurMark vs GPU Caps - Stress Issue & Temps Surfer_2099 Overclocking, Tweaking and Benchmarking 3 October 23, 2009 08:46 PM
Problem or not ? Kilauea Air Cooling 8 August 5, 2009 11:58 AM
Furmark and SLI BT! Overclocking, Tweaking and Benchmarking 7 March 28, 2009 09:03 PM
Hardware problem or HAL problem? andynerd Troubleshooting 1 March 7, 2009 09:03 PM
Little problem. belgolas HardwareCanucks F@H Team 9 February 9, 2008 10:05 PM
