Old June 30, 2010, 10:25 AM
Default 32bit or 64bit for gaming?
Hello, i just made a whole new computer
HD 5970
Phenom II x6 2.8ghz
bla bla bla ;)
Is there any games which requires more then 3gb ram?
Or is a 64bit Windows 7 ultimat best?
32 or 64 ? :) i got 8gb DDR3 1333 hz
thanks for viewing :)
Old June 30, 2010, 10:30 AM
Arinoth's Avatar
There is no point in not going 64Bit as its the way software will eventually or more so be going. Hell i think its even cheaper on ncix buying 64bit over 32bit as i believe its going to be the os standard for a while
Here I am: here I remain
Old June 30, 2010, 10:55 AM
If you have a 64-bit capable system (as basically everything is nowadays), there is no reason to use a 32-bit OS.
Old June 30, 2010, 11:28 AM
bojangles's Avatar
I thought that this was settled a long time ago.
However, to answer your question, read the last couple posts :P.
Old June 30, 2010, 01:08 PM
Silvgearx's Avatar
You got 8GB of ram and you ask about 32bit or 64bit?
Old June 30, 2010, 04:14 PM
Kommie986's Avatar
30 day no-questions-asked return on most Canadian hardware retailers FTW, eh?
Old June 30, 2010, 04:45 PM
MrDiaz's Avatar
Yeah go with 64 bit mate if you want to put to use those 8GB of RAM you have installed
-- Viva Canada! --
Old July 1, 2010, 01:53 AM
m1dget's Avatar
I have to agree with you. Pointless to have that much memory especially if it's for a gaming computer. It's better to return it to the store if possible.
I would not say the same for video/photo editing/rendering, compiling, something that needs a mfs or whatever else that requires that much ram... but for gaming it's just ridiculous.
To answer the OP more directly; there's no reason to go with 64 bit in windows world unless you do the above (minus gaming) and need that much ram or need to use an application that was only compiled for 64bits.
"NIX is a classic example of security through obscurity because there is no real monetary reward for crackers and hackers to break Linix" -AkG
Old July 1, 2010, 02:29 AM
64 Bit all the way
Cheers; Snarl
Another Guy From Canada
Old July 1, 2010, 07:02 AM
Better question might be which version, right? I might 'upgrade' to 7 (well, buy OEM) but I see no reason not to get just Home Premium 64-bit. Is it just old software that only has XP versions that wouldn't work on it? Is that how it works? I wanted to make that clear. I believe it's the case but want it confirmed. I don't even want to get a 'new' Windows OS (LOL!) but I'm out of XP copies and want a legit copy. I'm giving my old computer to someone so I'm letting them keep the XP on it.
The new build I'm going to have and install 7 (I guess). I can network the two computers and each computer can access to the other (including writing/copying files to and from), right? The differences mostly regard compatible programs? I even read that there were some workarounds for 'XP only programs' or something like that?
32bit vs 64bit chang2 O/S's, Drivers & General Software 73 September 30, 2009 04:52 PM
XP? Vista? 32bit? 64bit? 7? RainMaker O/S's, Drivers & General Software 30 January 13, 2009 07:08 PM
Vista 32bit or 64bit for gaming cndian O/S's, Drivers & General Software 54 December 10, 2008 06:47 PM
32bit Vs 64bit XP enzeo O/S's, Drivers & General Software 6 September 28, 2007 01:53 PM
Vista 64bit vs. XP 32bit 4GB RAM bench comparo Eldonko O/S's, Drivers & General Software 13 May 14, 2007 01:09 PM
