Old June 28, 2010, 09:22 PM
Default best multi-core optimized freeware?
I just put together my first quad with the AMD 635.
What are some cool little apps which show off the speed of multi-core cpus?
mike
Old June 29, 2010, 01:31 AM
m1dget's Avatar
prime95 o.O
make -j 5 $blargh D:
...to be a bit more serious usually some video/music converter use them pretty well if you want to do simple ('biased') benchmarks
"NIX is a classic example of security through obscurity because there is no real monetary reward for crackers and hackers to break Linix" -AkG
Old June 29, 2010, 04:59 AM
gingerbee's Avatar
cinebench10 or 11
CPU PhysX Multi-core hack Bojamijams Gaming 6 September 30, 2009 11:27 AM
best freeware for my system ebdoradz O/S's, Drivers & General Software 7 July 23, 2009 05:45 PM
Synchronization Freeware misterlarry O/S's, Drivers & General Software 1 May 20, 2009 06:06 PM
Windows XP multi core optimization from MS Eldonko O/S's, Drivers & General Software 5 October 1, 2007 07:35 PM
New OCZ RAM optimized for AM2, AM2+ CPUs Babrbarossa Press Releases & Tech News 8 May 9, 2007 12:50 PM
