Old June 28, 2010, 09:14 AM
mjpd1983's Avatar
Default Whats the best CPU temp monitor software? what do you guys use?
So what's the favorite CPU monitoring software going around these days?
Whats the most efficient and accurate?
Cheers
Old June 28, 2010, 09:26 AM
Arinoth's Avatar
I find Real Temp gives me the most accurate temperatures with all my systems other then the atoms. Its kinda useless for that as it reports temps ridiculously low
Here I am: here I remain
Old June 28, 2010, 10:15 AM
Real Temp or Core Temp.
Old June 28, 2010, 10:21 AM
Soultribunal's Avatar
Just remember, Real Temp I believe will only work on Intel CPU's not AMD.
Thats why I suggest Core Temp, or Everest (I use both side by side).
ST
www.realhardwarereviews.com
Old June 28, 2010, 10:24 AM
ST
Real Temp only works on Intel CPUs, but it is better for that purpose than Core Temp. That's why I recommend Real Temp for Intel systems and Core Temp for AMD systems.
Old June 28, 2010, 10:27 AM
ForTheGG's Avatar
Real Temp or Core Temp as the others have mentioned. If you'd like a more comprehensive temperature report about your computer, get Everest.
"Sang Noir"
-Cooler Master Storm Sniper Black Mesh Edition
-Intel Core i7 920 D0 @ 4.116GHz 1.318VCore 24/7 HT On
-Corsair H-50 + 2x Cooler Master R4
-Asus RoG Rampage III Extreme
-6GB OCZ Platinum Triple Channel DDR3-1600 [7-7-7-20]
-2x EVGA GTX 295+ Quad SLI
-Corsair HX-1000
-WD 160GB Raptor 10000RPM
-WD 1000GB Black 7200RPM
http://valid.canardpc.com/cache/banner/1249140.png
Old June 28, 2010, 10:32 AM
gingerbee's Avatar
real temps is my fav but like others have said coretemp everest work too. i prefer real temp
Old June 28, 2010, 10:50 AM
Supergrover's Avatar
Coretemp, I used to use Everest faithfully but have been using HWMon pro more often than not nowadays.
R.I.P.
Old June 28, 2010, 05:31 PM
mjpd1983's Avatar
Thanks for all the suggestions guys
I'll give them a try
Cheers
Old June 28, 2010, 06:13 PM
Digikid's Avatar
Coretemp and Realtemp.
Just installed new GTX 260, what program to control fan and monitor temp? The MAX Overclocking, Tweaking and Benchmarking 5 January 16, 2010 01:36 PM
CPU temp vs Core temp phil3_66666 Air Cooling 4 July 31, 2009 09:39 PM
whats is a good monitor that can double as a TV Shadowmeph Display Units 13 July 22, 2009 11:39 AM
Q about real temp by intel and CPUID monitor contractk Overclocking, Tweaking and Benchmarking 8 March 29, 2008 09:51 AM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
