Old June 29, 2010, 01:49 PM
Speedfan, Coretemp. Does it matter, they are all reading from the same sensor (on-die).
Old June 29, 2010, 01:56 PM
SugarJ's Avatar
Actually, how they interpret the data from the sensor matters. It's not on a 1 to 1 scale. Thus the preference for a calibrated program like Realtemp.
Old June 29, 2010, 09:23 PM
burebista's Avatar
For Nehalem and latter calibration isn't necessary anymore. TJMax (in fact TJTarget) is written in CPU MSR so no more guess about it.
As for using RealTemp or CoreTemp is a matter of personal taste. Knowing unclewebb I prefer RealTemp of course. :)
If it ain't broke... fix it until it is.
Old June 29, 2010, 09:30 PM
everest all the way
Old June 29, 2010, 10:37 PM
It is a 1:1 scale. Real Temp can be somewhat calibrated for idle temps, but those are worthless anyway. As far as useful temperature measurements go, all monitoring programs read the distance to Tjmax straight from the DTSes and extrapolate the temperature based on that and the known Tjmax values. The reason Real Temp is generally considered the best is because it uses the "most accurate" estimated Tjmax values for older 65nm Core 2 CPUs for which Intel never released specific Tjmax values. However, for anything newer, the true Tjmax values are known, so it doesn't really matter which program you use. It all comes down to the UI you like the best.
Just installed new GTX 260, what program to control fan and monitor temp? The MAX Overclocking, Tweaking and Benchmarking 5 January 16, 2010 01:36 PM
CPU temp vs Core temp phil3_66666 Air Cooling 4 July 31, 2009 09:39 PM
whats is a good monitor that can double as a TV Shadowmeph Display Units 13 July 22, 2009 11:39 AM
Q about real temp by intel and CPUID monitor contractk Overclocking, Tweaking and Benchmarking 8 March 29, 2008 09:51 AM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
