Old November 23, 2007, 01:29 PM
Rapid-X's Avatar
Default cd key
bought a oem cd key now it wont install any ideas???
Old November 23, 2007, 02:00 PM
Cptn Vortex's Avatar
Call up MS and give a lame excuse that your HD failed so you need to reinstall.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old November 23, 2007, 02:02 PM
Can you elaborate a bit?
Does it reject the key?
Does the installer hang?
You can bypass entering the key during the install, Vista can run up to 4 months without entering a key.
Q6600@3.2ghz
Asus P5N32-E Sli
4gb OCZ Platinum DDR2 @1100mhz
Antec P180
BFG GTX 260 Core 216
Corsair HX-620
Thermaltake Power Express 250W
Raptor150, WD 500gb. WD 300GB
X-Fi Extreme Music
Old November 23, 2007, 02:53 PM
Gav's Avatar
Gav Gav is offline
Administrator
Also, make sure you are using an OEM CD as they key won't work on a retail version.
Old November 23, 2007, 04:05 PM
Shadowmeph's Avatar
this is my thoughts exactly OEM CDs are different then retail I found that out when I lost my win xp oem cd key that I got with my Dell comp lol
Old November 24, 2007, 09:36 PM
b1lk1's Avatar
You can use ANY key with ANY install disk for Vista. I just used an OEM key for Vista Ultimate with a Vista Upgrade Premium install disk.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old November 24, 2007, 11:25 PM
JD JD is offline
I'm pretty sure every Vista DVD out there that you can buy is the same. The key just tells it what version to install.
Your (Rapid-X) going to have to explain your problem some more though.
Old November 25, 2007, 11:24 AM
b1lk1's Avatar
Yes, you said it much better than I did, lol. Any disk can be used with any legitimate key. You can use a Vista Home Basic disk to install Vista Ultimate if you have a legitimate Ultimate key.
Old November 27, 2007, 09:38 AM
Rapid-X's Avatar
Default lol
called up vista and they gave me a ultimate key so im great now
Old December 20, 2007, 06:51 PM
I'm happy you could fix your problem, but I'm about what is a OEM CD, would you explain it to me please??
Why are they different from the others?
