Old June 17, 2010, 10:58 AM
Synth's Avatar
Default Web development testing platform required
Hey guys,
I develop XHTML-PHP-MySQL sites and apps.
I usually either develop on my Windows 7 and upload to my webhost to test my PHP/MySQL, or develop on a PC running Ubuntu w/ a LAMP.
Is there an easy way to develop in Windows and not have to upload the files to my host to test?
I have used XAMPP in the past, and remember liking it... Anybody familiar with that platform, or anybody know of a good alternative.
I'm looking for a (relatively) easy and simple way to do it all in Windows7.
Cheers!
Old June 17, 2010, 11:26 AM
JD JD is offline
XAMPP is still around and works great. All I'd really suggest.
Old June 17, 2010, 11:43 AM
MrDiaz's Avatar
Yeah can use either XAMPP or WAMP. They're the same thing really, you can even build your own test environment but either one works great
-- Viva Canada! --
Old June 18, 2010, 06:14 AM
Synth's Avatar
Which one is better, or easier to setup in your opinion?
Old June 18, 2010, 07:25 PM
Else, you could think about running a Linux OS inside a virtual machine on your Windows system.
New CPU Block required Wall86 Water Cooling 5 July 11, 2009 11:54 PM
How Does FAH Code Development And Sysadmin Get Done + Twitter LCB001 HardwareCanucks F@H Team 0 June 27, 2009 08:52 PM
Are there any jobs in game development now or in the next 4-5 years? andynerd Gaming 0 June 3, 2009 06:15 PM
Gaming/Development Pc ! ddrmanxbxfr New Builds 3 January 5, 2009 03:57 PM
Slow development of a new system gsp5322 New Builds 10 August 14, 2008 05:01 PM
