Old May 7, 2010, 06:43 PM
Socrates_Johnston's Avatar
Default MagicISO options will not go away after uninstall
hello.
I recently uninstalled MagicISO, but it seems that the right-click options will not go away! Observe:
It's a minor issue, I know..but there has to be a way to remedy the problem without having to install my OS again!
Old May 7, 2010, 08:34 PM
JD JD is offline
This will take care of it no problem: ShellExView - Shell Extension Manager For Windows
Just find MagicISO in there and disable it.
Old May 8, 2010, 06:40 AM
that did it. thanks dude.
would you suggest any other tweaks with that prog?
Old May 8, 2010, 08:45 PM
JD JD is offline
I personally disable anything else that I don't want. Can marginally speed up right clicking.
Old January 17, 2013, 09:27 AM
Trial Member
Default thanks for the start r
disabled the shell ext for magiciso - but it is still holding onto an iso - requiring its use to burn - which btw - didnt work in the first place - I want the bad mistake gone from the pc
Old January 17, 2013, 01:36 PM
JD JD is offline
If you go into the "Default Programs" option in Control Panel, you should be able to re-assign the file association.
Joystick Options lcdguy Gaming 4 March 5, 2009 06:57 PM
Uninstall Linux Kilauea O/S's, Drivers & General Software 4 May 14, 2008 10:21 AM
Trying to uninstall COD4 and.....reinstall a new copy.. Canadianguy Gaming 3 March 19, 2008 04:59 PM
What would be the best way uninstall..... Canadianguy Video Cards 2 December 7, 2007 07:15 PM
Options.... if any? 3.0charlie O/S's, Drivers & General Software 16 July 8, 2007 10:20 AM
