Old November 6, 2007, 08:30 PM
Default Edit dual-layer iso(5gb+ .iso files)?
Any one know a software that will let you edit dual-layer dvd image?
I have been using UltraISO to add files to backup I do of my system but now I just started to get my .iso over the 4.5GB limit that UltraISO can read does anyone know any software that will let you add files on bigger iso image?
Like I don't want to unrar the whole .iso then add the file then iso the complete directory..that's what I am doing right now but damn it's sooooo long.
And another example is when I buy a game I often do a copy that I bring to friend places so I don't scratch the original disk and I often like to add the games updates directly on the dvd so I use UltraISO but now that most of the games are on dual layer UltraISO is no more a choise..got to put all the files on the hardrive add the update.exe then re-create the dvd.. that is again a long process.
Thanks in advance guys!
Old November 6, 2007, 08:37 PM
Try MagicISO
NVidia urges mfctrs to go from 10 to 6 layer pcb Babrbarossa Rumor Mill 12 May 15, 2008 07:14 AM
Widescreen and avi files? bobaban Display Units 0 November 23, 2007 04:06 PM
Auto edit BrainEater Suggestions & Feedback 3 March 19, 2007 11:16 PM
