Old November 3, 2007, 09:47 AM
Shadowmeph's Avatar
Default DVD writers are not showing up
I did a fdisk reinstall of my OS and now my dvd writers are not showing up in my computer, there are showing in device manager with the yellow tag on them but when I try to up date them it gives me the message that updater couldnot find a better match for the dvd writers
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old November 3, 2007, 01:21 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Did you try uninstalling the IDE channel they are on in device manager (IDE controller --> primary or secondary ide controller -->uninstall). I find when xp screws up like that this works. On reboot XP finds 'em and reinstalls them properly. The only thing to watch out for it to pick the right one and make sure that your OS drive isn't on that controller...that might make things tricky
Hope this helps.
Old November 3, 2007, 01:42 PM
try this
missing CD drive not repaired with FIXCD.REG - Tech Support Guy Forums
Old November 3, 2007, 08:32 PM
Shadowmeph's Avatar
Thank you for your replys I fixed the problem by using this script worked perfectly
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
"Upperfilters"=-
"Lowerfilters"=-
Folder :
TAT is not showing the real temp! Why? francois methot Overclocking, Tweaking and Benchmarking 5 March 12, 2007 09:32 AM
