<~----> This may be a incredibly stupid question but... - Hardware Canucks
Old April 18, 2010, 03:58 PM
Default This may be a incredibly stupid question but...
Does Windows 7 64bit support booting from a USB flash drive and running and a MS-DOS application?
Old April 18, 2010, 06:06 PM
ipaine's Avatar
Do you mean like booting into DOS from a USB stick?
If so then I would guess you would be out of luck as you are going to have issue with DOS being able to read the USB. A much easier way would be to either run DOSBOX or a VM with DOS loaded on it.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old April 18, 2010, 06:26 PM
Digikid's Avatar
There are no such things as stupid questions.
iPaine has the correct answer.
Old April 18, 2010, 07:07 PM
Edit Arinoth: Hacking of any sorts is not permitted discussion on the forums. With the latest XBL update any flash drive and a good number of usb external hard drives can now be formatted and used as storage devices (as if the standard xbox 360 hard drives). Write times to the flash drives are slower however write times to the usb hard drives are approximately the same amount of time as the xbox 360 hard drive. Read times are all the same across the three storage mediums
Old April 18, 2010, 07:22 PM
JD JD is offline
Not quite sure what your asking...
But maybe this is what you want? HOW TO: Making a USB Thumbdrive Bootable
That will let you boot from your USB and it'll load up DOS.
Old April 18, 2010, 07:24 PM
gingerbee's Avatar
yup sent to him great guide forgot about it
Potentially Stupid question about bootable image dadzilla O/S's, Drivers & General Software 10 July 15, 2009 04:14 AM
Stupid question but is this possible? Zippoh CPU's and Motherboards 13 January 11, 2009 10:41 PM
Stupid HWC ranking system question :D shayan288 Off Topic 2 January 8, 2009 03:28 PM
A stupid question...im just paranoid Zippoh Off Topic 11 November 18, 2008 03:41 AM
This might be a stupid question.... no_pulse Power Supplies 2 July 13, 2008 08:00 PM
