Old October 28, 2007, 08:56 AM
DSNB's Avatar
Default Configuratoin Error?
Recently I just made my own rig (the one posted @ ATI section is shared one), the only thing I took from HP computer is the HD... I did this since the HP pc = broken.
Now when ever I turn the PC on i get configuration error! Some people told me to repair or format it... how on earth can I do that?
Old October 28, 2007, 09:39 AM
sswilson's Avatar
When you install XP it will ask you what you want to do with the hard drive. What you need to do is actually delete all partitions from the drive and create a new one (or more if you wish) before installing the operating system.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC (Half Height) / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old October 28, 2007, 10:25 AM
Mr. Cipher's Avatar
do keep in mind that formatting/repartitioning will cause you to lose all your data...
I that happen to me once too, and what I ended up doing was buying a new HDD and installing XP on it, then copying my old files from the old HDD to the new one, then cleaning the old one. I did this because I don't know much about HDD backup/imaging software.
Costly repair back then, however 500gb HDs are ~$100 now if you want to go that route and have your data.
Either way the length of time to fix it is barely longer than a routine install of XP!
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Old October 28, 2007, 10:55 AM
If you're getting a new drive, there's no point in copying your files over to the new one. Just install the old drive and use it as the secondary drive.
Old October 28, 2007, 04:39 PM
Mr. Cipher's Avatar
That's true too...
I'm a formatting freak, though that would have saved me alot of time.
i7 Red
C2Q Blue
Old October 28, 2007, 05:43 PM
DSNB's Avatar
D'oh, so I now need to buy OS now
Old October 28, 2007, 05:51 PM
sswilson's Avatar
Yep, it is virtually impossible to re-use the OS from one of the big-box pre-builds as they are directly tied to the hardware, and the license is through the computer manufacturer rather than through microsoft. (Even to the point that microsoft's official policy is that all OS tech support for them should be done through the computer manufacturer rather than through the microsoft site).
Vista error biff Troubleshooting 3 March 2, 2008 07:46 AM
Prime 95 Error RogerzRig Overclocking, Tweaking and Benchmarking 52 February 20, 2008 10:03 PM
Pricing Error?? oldbetang RAM 37 February 14, 2008 11:41 PM
Display error Jim Video Cards 3 February 8, 2008 06:45 AM
Windows xp error, as usual omgwtf O/S's, Drivers & General Software 11 May 31, 2007 05:54 PM
