Why don't you write a macro for this?
1. Copy one of the addresses you need to the clipboard.
2. In Excel, Click a cell in the spreadsheet.
3. On the View tab, Macros panel, click Record Macro.
4. Enter a name for the macro (something like PasteWithDest)
5.Assign a shortcut like CTRL+H.
6. Click OK.
7. On the Home tab, Clipboard panel, click Paste.
7. Click the paste options pulldown, and select "Match Destination Formatting".
8. On the View tab, Macros panel, click Stop Recording.
That's it. Your macro will paste and change the destination formatting everytime you run it (in the case here, you press CTRL+H).
Is this what you needed?
