Old March 18, 2010, 09:33 AM
zc1 zc1 is offline
Does the bezel compensation work?
My Rig (Photos):
Engine:
Q9650 @4.05 GHz on GA-EP45-UD3P // Noctua NH-D14 Heat Sink + 3x CM R4 // Mushkin Blackline PC2-8500 2GBx4 @ 900 MHz
ECU: OCZ Vertex Turbo 120 GB SSD // 3x Seagate Barracuda 500 GB // LG 22X and Philips 20X DVD-RW
Fuel Pump:
Corsair HX1000
HUD: 2x 5870 Vapor-X + 3x SyncMaster 2243
On-Board Video: Hauppauge WinTV-HVR-2250
Chassis: FT02B-W
Projects: [ 5870 CF-X vs Non-CF-X | NH-D14 vs H50 ]
Old March 18, 2010, 10:26 AM
Will they evvvvvvver fix the stupid CS:S lighting problem?? :(
Talking about FPS (finger pointing syndrome)
heatware
Old March 18, 2010, 10:45 AM
zc1 zc1 is offline
Just downloaded and installed. Bezel compensation does, indeed, work.
My Rig (Photos):
Engine:
Fuel Pump:
Corsair HX1000
Chassis: FT02B-W
Old March 18, 2010, 12:23 PM
TimTheEnchanter's Avatar
Same for Anno 1404, they won,t fix it.
Old March 22, 2010, 04:46 AM
cozmosland's Avatar
i have found no problems so far
Old March 22, 2010, 05:24 PM
SimGamer's Avatar
Nope, crashed in ARMA2 with these grey screen and then BSOD, ran choppy as well. Rolled back to 10.2 for now. I'll wait for the WHQL's to show up on the XFX site.
BTW what's with the deal of ATI drivers being able to be installed on top of older versions? On the Guru3D forums they were saying that is the way AMD recommends it. I always wiped my nVidia drivers before installing new when I ran with the green team.
Old March 22, 2010, 05:51 PM
Dr_BenD_over's Avatar
I've always just installed the new drivers over the old ones, team green, team red, team whatever colour 3DFX was was...
If it's stupid and it works, it isn't stupid.
Old March 24, 2010, 01:28 PM
i have problem with 10.3 drivers. When you run the Everest program shows me BSOD, before it was all right. You attach a picture BSOD, Please Help
  #19 (permalink)
Old March 24, 2010, 02:16 PM
GPU-Z doesn't work right either, I'm guessing some changes were made that affect these programs.
  #20 (permalink)
Old March 24, 2010, 02:23 PM
The official 10.3's are now up.
100m Cat 6, Where Can I get It bangegat Networking 15 January 28, 2010 04:54 PM
ahem...cat porn Gellidius Off Topic 17 August 28, 2009 09:06 AM
Cat just peed on couch... Chos3n Off Topic 22 June 22, 2009 06:51 AM
CompizFusion scared my cat solaris10 Off Topic 8 June 9, 2009 12:58 PM
