Unable to reformat pc, error keeps popping up! Hey!! As the title says, everytime i try to reformat my pc an error message pops up saying that "Windows cannot access the required file D:\Sources\Boot.wim.". How do i fix this problem? Thanks in advance! |
More system specs please, also at what point in the format does this happen? |
Is this a legit ISO of the OS? The disk apparently is missing a file........ |
^ bingo my thought too. burned disk that messed up |
naughty, naughty! :haha: |
intel i5 750 Seagate 1TB 4GB ripjaws XFX 4890 Corsair H50 umm after step 2 or something of the process the message pops up |
any scratches on the disk then? |
Ok, so if it's a proper install disk, first try to get your hands on a different install disk (just use your own personal key) and if that doesn't work, it's time to start eliminating hardware that might be faulty, and thus failing once the OS installs the full drivers for it. Try running a boot memtest cd (obcd is my choice), if that doesn't find any issues then turn off all "extra" hardware in your bios (things like audio / lan / Floppy disk controllers / etc.... ). |
| All times are GMT -7. The time now is 07:51 AM. |
