Old March 17, 2010, 10:03 PM
Is your HDD SATA? 1TB Seagate sounds like it is.
Maybe your Mobo and BIOS is in IDE emulation mode. I would check which mode you are using. I would suspect you would want AHCI SATA mode and if you need to change to that, it might solve your problem.
I'm just throwing it out there. I probably don't know what I'm talking about. LOL!
I always google the error msg and see what can be found. One link seemed to suggest Windows 7 prefers SATA disks and I thought maybe it works better in AHCI mode. I believe this especially applies to using a SATA DVD burner as well. Maybe it's good if both drives are SATA.
Old March 17, 2010, 10:24 PM
I'd download another copy of the install disc (via torrents or what have you), burn it and try that disc first. I'd have to agree, the disc itself sounds damaged.
5970 with 285 benches before reformat gerardfraser Video Cards 7 November 26, 2009 09:57 AM
heard gtx285 very high crysis have textur popping hohohee Video Cards 2 May 5, 2009 07:28 PM
Popping and cracking on integrated sound chrisk Troubleshooting 9 March 22, 2009 11:27 AM
reformat prob(posting for friend) cmac79 Troubleshooting 19 August 10, 2008 08:45 PM
AVG notice just started popping up saying it's discontinued.... Misoprostol O/S's, Drivers & General Software 19 January 6, 2008 09:12 AM
