-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   W7: How to sort desktop icons by DATE CREATED (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/29617-w7-how-sort-desktop-icons-date-created.html)
oblisk March 8, 2010 03:05 AM
This is a feature I miss tremendously from XP. The closest thing I can do is sort by date modified, and desktop is where I put a lot of my new files. They go all over the place. And if I copy an older file to desktop, they go right in the middle of my icons. And yes, I need a lot of icons on my desktop.
tl;dr: How to sort icons on desktop by Date Created?
Iceman March 8, 2010 10:40 AM
I'm not sure how to sort them, but if your goal is to keep your desktop organized, you might want to check out a free program called Fences by Stardock. I also have a large amount of icons, and I find the program really helpful.
You can check it out here.
KeepSix March 8, 2010 12:04 PM
I don't want to come off sounding like a #@$$, but I recommend changing your procedure by putting your 'new files' in a separate folder, not on your desktop.
3oh6 March 8, 2010 12:04 PM
looks interesting, wonder if that will play nice with d-color...
unfortunately it doesn't play nice at all. looked like it would have really been nice.
CMetaphor March 8, 2010 12:47 PM
Forgive me if I'm sounding obvious with this... When you a create a new file on your desktop isn't the new file always tacked on at the very end of the list? Leave it as is?
Zero82z March 8, 2010 02:42 PM
Disable auto arrange, and Windows will not automatically sort your desktop items. Then sort them how you see fit.
JD March 8, 2010 04:47 PM
Navigate to your User\Desktop folder.
Right click > Sort By > More
Check off Date Created > OK
Right click > Sort By > Date Created.
That what you want?
